Lq9 turbo best compression
First off, Why in the world would you bore and stroke the crap out of a stock block for cubic inches that aren't needed to get to your goal? You weaken the block and spend a mint on a rotating assy. Then add a baby turbo to big cubes? It will be a torque monster...you want less TQ down low, and big HP up top... esp for a street car IMO.
If the goal is a weekend warrior street strip car that will run 9's. Run an Alum gen 4 5.3 and don't touch the bottom end. (gen4 6.0 is fine too but again...whey spend the extra $) If you have the money for a 408 stroker, drop a set of decent heads on the 5.3 and go to town. I'd keep it at 9:1 or under for pump gas personally. You shouldn't need 1000+HP to get there either, unless you weight 5000lbs.
As a quick example my cam only notch mustang with full interior is trapping 134 on 12lbs. I run water/meth and no intercooler. It has 241 heads (68cc) I'm on 19lbs now and it feels like a 140+ trap car easy. Twin 64/62's cheap china GT35 clones. Spool up is crazy fast. And i'm running a 2.73 gear, so not exactly optimal for track duty. Toss an intercooler on it and gear it properly and it would be a 9 sec car easy. I do run e60 because its cheap and handy. But i'm pretty dang confident I could run the same boost with pump gas. Just an example of how a bunch of mismatched low compression junk could still hit your goals. A well thought out 5.3/6.0 could easily do it. I have to pull a TON of power on my janky setup to get it to plant the tires on the street. Last thing I'd want is another 100-150 ft lbs NA at low RPM to deal with.
Just a thought...
What engine and turbo combo would spool well on the street at a lower boost level with street friendly cam, stall, etc , while still enabling you to hit 8.5 - 8.7 at the track at higher boost level on 110 octane. Assume you are willing to pay a little more to be durable like spending the $$ on a rotating assembly, ARP, etc so that you aren't tearing into the block every few years, but you want to avoid the extra $$ required stepping up to the aftermarket block. We aren't talking about a 1500hp combo here, more like trying to do this hitting the occasional 1100-1200 rwhp on 110 octane using a factory block. Assume the car is dialed in for suspension at the track, and that you are cutting 1.3 sixty foot times launching off a trans brake in a 4L80E.
Point I was trying to get across is an 8.9:1, 2.73 geared, 5.3 will easily make more torque and low end power than you can plant on the street. 650 ft lb at 4k will haze the tires just well at 700-800-900-1000 etc... It's all a smoke show if you cant stick the tire.
Eh... the goals are shifting rapidly. Making it to the 9's is one thing. Now you are talking about dual purpose street/strip car going 8.5's at 4000 lbs. You will need over 1000hp to do that. That's a whole new ball park there, big money! Better in my opinion to get 2 cars and make one fast than try and make a 4000lb car have good street manors and run 8.50's. That's a tall order. Esp. if you want any kind of reliability. I wouldn't use any stock block stuff for that goal. Jump right into a aftermarket block and super tough short block. Keeping engines and drive-lines alive at 4000lbs and 8.50's is also hard...aka big $. It makes little to no sense to want a 4000lb race car IMO. But hey if money was no option, why not!
You should also check your facts a bit on Iron VS alum and strength. The block castings are different on the alum 5.3's. They have Siamese bores and are as strong if not stronger than the iron 5.3's or 6.0's. Also if you start boring and stroking the 4" plus big bore stock blocks you make them even weaker. Again, not something you want at 4000lbs and 8 sec power. Only option there is to go with an aftermarket race block if you are serious about it. Then the more cubes the better. Hell a BBC makes more sense at those power levels and weights, IMO.
Instead of building a block that will last a long time... Why not keep the setup simple and cheap and let a big turbo(s) do the work. If the engine lets go, have a spare stock long block sitting there waiting. Build the turbo kit in a way that makes for easy 4 engine removal. I can literally have my engine and trans out in under 4 hours. (and I didn't particularly set it up for quick removal) Engines are the cheap part these days. If the tune is "on", you shouldn't be burning through them. And if the tune is "off", the big $ motor will torch itself as well.
Also in my experience, things go wrong when racing, period. Doesn't matter if you have a $10k long block or a $500 long block. You'll get bad fuel, an injector will clog, a spring will break etc... And for the average guy just playing and not racing competitively... I'd rather destroy a "cheap" long block and replace it. Hell SBE 4.8's are making 1200-1300 hp these days with a cam and untouched heads. Running 7's at 40+ lbs of boost. I'm not suggesting you go buy a bunch of 4.8's... just that big boost is the cheap/easy way to power IMO. Which Is also why I favor lower compression motors with big power goals. If your engine only makes 400 chp NA, You'll have to run 30+lbs to get it to move. Which is why I don't like the idea of high compression ratios. Yet, if your making 650 hp NA, then you can hit your goals on low boost, then higher compression ratios are ok. It's a give an take kinda thing.
You may also consider a dual fuel setup, esp if your doing a dominator ECU. Run 16 injectors and pump/race gas. You'd be surprised how much money you save only using the race gas while under high boost. 5 gals last a long time! Also you don't need to just run the race gas or just run pump fuel. You can add a percentage of your total fueling. Say 15% c16 at 10-15lbs and 50% C16 at 20-25lbs. Alot of options out there!
Because only three of us in Taiwan swap Ls.
The three people in Taiwan swap LS, but only swap the inventory engine.
So I simply don't know where to go for answers.
Can only come here for help.
[img]data:image/png;base64,iVBORw0KGgoAAAANSUhEUgAAABQAAAAUCAQAAAA ngNWGAAAA/0lEQVR4AYXNMSiEcRyA4cfmGHQbCZIipkuxnJgMStlMNmeyD2d wmc8+sZgxYJd9ErIZFHUyYYD7fkr6l4/rnvmtl7+KitrqV/fq2Y5eLY3Z9S48eRLe7BmVZ9qhTLhQ0algzZWQOVKSsCF8OjAn wbxDTWFDUhPK/jMr1H6HE/IqRky2DyvCefuwItwZzodVoYRiLqMkVCXrwpJ9twZ+sgfDYEFY l8wIWxZ9uFf7zkallxlJh4YrLGsKjZRx7VGHhLqwgFUN45DGdb 8MeXGpgB4ABZdeDcpZEY51A+hyLKz4S1W4MQWm3AibWtgWmk6d yISa1pSdyWTOlLXVp0+eL9D/ZPfBTNanAAAAAElFTkSuQmCC[/img]
My take: higher compression will work, however, it’s more dangerous and the line you may cross from safe to dangerous....is much thinner than with lower compression. I feel like the lower compression allows more boost, more timing and more power. I could probably run 87 octane on 8-10psi.
Just my .02
