5.3 vs80 power output ?
5.3 gen 4 bottom end
vs80 billet T6 1.32
14lbs boost
2.5” crossover
twin 44mm wastegates making 14psi
3” ic piping with 3” intercooler and 50mm bov
fic 1000’s and twin walbro 450 -8 fuel system
Btr stage 2 turbo cam
tbss intake
through a TH400 3400 tci stall converter.
what have you guys with this real similar set up made on about 10psi and about 14-15psi??
holdener has posted many vids with stock cam 5.3’s with headers making about 350 flywheel hp. That cam he listed should put it over 400.....
Your not going to make 40HP at the wheels with a pound of boost unless you make 600+ at the crank NA. Numbers are defiantly screwy. Iced W2A intercoolers let you fudge that a bit, but for the most part take your NA power and divide by 14.7. That's roughly what a healthy turbo system will make per pound at the crank. Doesn’t matter if you have a thumper 100+mm or an 75mm. As long as your on a decent efficiency island on the compressor map and your back pressure isn’t through the roof, that’s what it will do. It’s not magic.
The 450's are great pumps, but people bottle neck them pretty badly with "Y" fittings. Its why you see all these nutty triple 450 pump setup things and people STILL have fuel issues. 2 450s should be enough fuel for 1200+ WHP. Easiest high flow setup IMO would be to run a -8 from each pump to each side of the rails. So each pump feeds 1 rail with a -8 line. Thats extreme overkill but your plumbing will never be limiting your pump flow. If you are set on a "Y" ensure you run at least 3/8 ID inlets(AN6) and a 5/8 (AN10) outlet.
Yes, it's just an estimate. usually pretty close when talking crank HP numbers. Following suit with doubling crank NA power per for every 14.7 lbs of boost or 1 atmosphere/1 bar of boost.
