Mild steel v bands
Old May 31, 2020 | 08:14 PM
fusion_ta66's Avatar
Default Mild steel v bands
Anyone running mild steel v-bands? It seems the vast majority run SS. I am welding onto factory exhaust manifolds, which are not stainless, so unless corrosion is a big factor, I thought using mild steel would be better in terms of thermal expansion and cost. I'm also looking at aceraceparts, anyone used their v-bands?
Thanks
Old May 31, 2020 | 08:52 PM
forcd ind's Avatar
I got some off Ebay, get the male/female, the others dont always center.
Old May 31, 2020 | 09:42 PM
Dragframe's Avatar
I use the frozen boost v bands. When I fit the pipe to them I have the pipe stick through one side of the v band into the other to get that male/female fit. Work great
Old Jun 1, 2020 | 09:06 AM
Jimbo1367's Avatar
pics?
thanks
jim
Old Jun 1, 2020 | 11:19 AM
Black_Sunshine_99's Avatar
Silicon intakes sell S/S ones that have a built in step into the mating surface that makes them a snap to assemble, plus you can add a small bead of copper RTV to fully seal them.
Old Jun 1, 2020 | 02:28 PM
truckdoug's Avatar
the step ones are good if you can control your heat well enough to prevent distorting them. otherwise you end up in the same pickle as before.
I always use at least 409SS, corrosion is a problem with high heat and the presence of h2o from the combustion process.
if you have a lathe you can make a nice heat sink. I'll take some pics of mine next time im in the shop.
limit weld length to ~1" and back step your welds so it doesnt pull. I'm almost at a point where I can keep them flat all the time.
another thing I've seen just recently is the actual turbine housing distorting a little after some pulls. this may be limited to the cheap low end turbos I use tho
Old Jun 2, 2020 | 08:46 AM
Hey Truckdoug, I'd love to see your heatsink. Is it made for a stepped vband? If so, which brand? Would you be willing to rent or sell me one?
Thanks
Old Jun 4, 2020 | 02:31 PM
truckdoug's Avatar
well i must have loaned them out coz I cannot find them
it's less of a v band and more of a stepped plug that fits inside the v band. the center is tapped 3/8-18 npt and it has a cut from that hole to the edge radially. when you tighten the npt plug into it, it expands. The plug on one of them is a 3/8-18npt to 1/8-27 npt adapter so I can run a purge line to it.
when i get them back from ???? i'll take some pics and measurements.
ive never thought of selling them since they take forever to make it'd be ridiculous cost-wise
Old Jun 7, 2020 | 01:57 PM
Slow boi's Avatar
i bought a 5 pack off ebay of the stainless vbands male'female. i just mig them on no cares
Old Jun 7, 2020 | 05:56 PM
GMCGreg's Avatar
Stainless v bands from VS here , mig welded to manifolds after BBQ pre heat , followed by BBQ cool down . 3 yrs dd and strip -no problem . One manifold has sch 40 pipe elbow welded to it with 309 stainless rod and old stick machine , same BBQ treatment. That one takes most of the turbo weight -all good. These are not stepped but a few extra minutes on assembly and you can get them lined up well
