Better top end or bigger head unit
Old Jul 14, 2020 | 06:19 AM
  #41
BCNUL8R's Avatar
Originally Posted by JoeMama's GTO
I have a 94 in my 06 GTO and I had to massage the fenderwell because of the bigger intake diameter. Also, I ended up using a 60 degree elbow for the intake pipe in order to get a big enough air filter in between the coil packs and computer area (you would and should relocate your coolant tank). I generally run 15 degrees over ambient sucking in the hot air and passing it through a treadstone IC.
What did you do with the coolant overflow? Did you keep the ecu in the stock position the procharger kit recommends?
If I had room without the coolant overflow in the stock location it might fit a bellmouth?
