Spool too fast?
Old Jun 13, 2020 | 07:30 PM
fusion_ta66's Avatar
Default Spool too fast?
I have had quite a few LS engines but this is my first time going turbo. Car will be 6 speed manual and weighs roughly 2900 with me in it. 99% street car. Aluminum 5.3 sbe. I will have a 4" downpipe. I was looking at the VS 7875 billet turbo and the VS gen 2 7875. Right now I'm looking for ~700whp but wanted to give myself some headroom. I was pretty set on getting the gen2 7875 until I saw this video from Richard Holdener that scared me a bit about the spool time:. https://youtu.be/AOEOFz_TjZA
But then honestly I was thinking that perhaps I want some lag time in the spool to help keep from blowing the tires off too easily and/or soften the blow to the drivetrain. I know that the car being a manual means faster spool would probably help at the track but the car is a street car.
Also thought I should really get something with a 4" exhaust outlet to match up with my downpipe.
Any thoughts? Maybe get a t4 s475 with a 1.1 AR? Other?
Thanks
Old Jun 13, 2020 | 07:36 PM
ddnspider's Avatar
The 7875 is perfect. You can deal with traction with your tune or right foot. Don't intentionally get a turbo too big or laggy unless it's a race car.
Old Jun 13, 2020 | 09:13 PM
7875 billet or gen2? If billet, what about the 3" exhaust outlet?
Thanks
Old Jun 13, 2020 | 11:02 PM
AwesomeAuto's Avatar
Thanks
The S475 in that video spooled significantly faster than the 7875.
Manual trans wont spool faster than an auto. Maybe RPM wise earlier, but not "time" earlier.
Old Jun 14, 2020 | 07:35 AM
ddnspider's Avatar
Thanks
You could get a billet 7875 on eBay for 260. Try it and see what you think. Run a cutout if you want more flow for higher boost.
Old Jun 15, 2020 | 07:48 AM
SLOW SEDAN's Avatar
Nothing slow about the spool of a 7875. I would get the gen 2 or gen 2.5 over the “base” model if you will.
You can control spool, boost ramp in, etc in the tune.
Old Jun 15, 2020 | 08:14 AM
Forcefed86's Avatar
If packaging isn't a concern, I don't see the appeal of the 78/75 when the S475 is proven to spool more quickly and meets his goals power wise. It's a tank of a unit and a better turbo IMO. Especially if you buy a "real" T4 1.10T4 S475 and not a knock off. They have been proven to 950ish wheel on small bore stuff and out spool the 78/75.
Check out ls1curt on this forum and his success with the T4 S475. 950whp and backed it up with 159 mph trap speeds at 3000lbs. And it spools more quickly... Seems like a win to me.
Old Jun 15, 2020 | 09:04 AM
ddnspider's Avatar
Isn't an S475 quite a bit bigger than a 7875?
Old Jun 15, 2020 | 09:37 AM
Thanks for all replies. I had a couple of follow up questions:
1) is having a 3" turbine outlet stepped up to a 4" downpipe a significant detriment vs a 4" turbine outlet paired to the same 4" downpipe?
2) what is the overall dimensions of an t6 s475 vs t4 s475 to a t4 7875?
3) is there such a thing as too quick of spool on the street? I am genuinely concerned about blowing the tires off, and the hit to the drivetrain. Car is a 6 speed, FYI
Thanks to everyone
Old Jun 15, 2020 | 10:47 AM
ddnspider's Avatar
Thanks to everyone
1) depends on boost and back pressure. Typically won't be an issue, especially with a cutout.
2) someone else will have to answer who has dimensions.
3) entirely personal preference. To me nothing is worse than a laggy turbo manual car on the street. Size the turbo right for the intended boost and power level and let the tuning deal with traction.
Old Jun 15, 2020 | 10:59 AM
Dragframe's Avatar
Adds significant expense though right? My BW t6 1.10 s475 was like $700? Doing a t4 is gunna add to that. but I’ll bet it would light fast! Mine does with the t6 (auto car tho)
The 7875 is gunna be way cheaper (if your a frugal guy like me lol). Guess it depends on priority.
Old Jun 15, 2020 | 11:00 AM
Forcefed86's Avatar
Yup, S475 is a big boy, almost twice the size as the standard older 78/75. That's why I mentioned the packaging thing first. If you have the room, its the way to go IMO.
A laggy setup isn't going to help you with anything. All that means is there is a delay in the power onset. Which is no fun with a manual. Then when the turbo does come on, it usually comes on violently. A lot of that can be tuned out.
Id stick with a twin scroll divided setup on a 1.10 T4 S475. Run a 2" hot side with a 38mm gate on each. Sounds more complex, but I found it easier than messing with merges. Also routing the 2" pipe is super easy and cheap. Small WG's are cheap as well. You can also double or even triple wrap the piping and insulate it really well for heat. I used mild steel and a mig. on factory exh. manifolds. No need to get fancy. Tough setup to beat spool wise IMO. I spool a S480 1.32 T6 with my 4.8 pretty darn well that way.
Old Jun 15, 2020 | 11:04 AM
Forcefed86's Avatar
Depends if you go knock off or not. The $270 78/75 on ebay is pretty darn appealing if they hold up.
You can get the billet "race whee" t4 S475 from VSR for $570 shipped. Thats the route I'd go.
Their Cast T4 S475 is $429. That's the route I'd go if I was on a budget.
Similarly priced to their 78/75's. But that Ebay special 78/75 is tough to beat price wise.
Old Jun 15, 2020 | 11:17 AM
Dragframe's Avatar
Man.... I need to quit buying turbos from Jose 🤣
Old Jun 15, 2020 | 11:41 AM
Can you link me to this turbo, I couldn't find it on their site for some reason
Old Jun 15, 2020 | 12:06 PM
ddnspider's Avatar
I <3 my $260 Ebay billet 7875 and it's held up fine at 1 bar of boost so far. Hopefully will turn it up at some point.
Old Jun 15, 2020 | 01:53 PM
Forcefed86's Avatar
https://turbo4less.com/product/vsr-7...ar-t4-divided/
Old Jun 15, 2020 | 06:05 PM
stevieturbo's Avatar
Thanks
No chance of spooling too fast.
And it's much easier to reduce/ramp boost on a fast spooling car, than it is to magically gain boost lower down in a laggy piece of junk.
Old Jun 15, 2020 | 08:36 PM
What do you guys think about these 3 options:
1)Billet s475 ( https://turbo4less.com/product/vsr-7...ar-t4-divided/ )
2)billet 7875 ( https://turbo4less.com/product/vsr-billet-7875-96ar-t4/ )
3)gen2 7875 ( https://turbo4less.com/product/vsr-n...n-7875-billet/ )
I asked VS about the size differences, he said
You are going to be around 1” difference in G1 7875 vs a s400 chassis unit.
The difference in g2 is ½ “
I like the gen 2 7875 in almost every way with the exception of the spool lag shown in this test by Holdener :
I like the spool, cost and size of the billet gen 1 7875, but don't like that the turbine has only 3" outlet
I like the s475 in terms of the specs on paper seem about perfect, but no data from others using it and it is the biggest, and for some reason I think that 1" difference might be a bit more than claimed.
Old Jun 16, 2020 | 07:27 AM
SLOW SEDAN's Avatar
It weighs over double! For people that care about things like that.
