Quickest time/trap on VSR S480?
Old Jun 15, 2020 | 03:29 PM
Forcefed86's Avatar
Default Quickest time/trap on VSR S480?
Just curious how far I can push the T6 S480. I know the "real" S480s have gone well into the 160's. Haven't seen as many "fast" VSR S480s.
Seems to still have some left at 158 and 3000ish. Wasn't picking up much from 22 to 24lbs on a 4.8 around 7k.
Old Jun 15, 2020 | 05:23 PM
ls3fox's Avatar
7 Second Club
I’ve been 8.01@169 with a gen 1 vsr s480
Old Jun 15, 2020 | 07:43 PM
jester1's Avatar
...as he licks his vanilla twist cone on the shift. Sorry couldn't help myself.
Probably the record for this turbo.
Old Jun 16, 2020 | 07:35 AM
Forcefed86's Avatar
Great run! that was on an LS3 I assume? What kinda boost?
thanks!
Old Jun 16, 2020 | 07:48 AM
SLOW SEDAN's Avatar
Not sure about "fast" as its a street car but the older VSR S480 made 850 on 18lbs and 1050 on 22-23lbs so didn't seem tapped out just yet. Same dyno 1,100 was enough to trap 165 in a heavier car so I'd say yours should have some left.
Old Jun 16, 2020 | 09:25 AM
ls3fox's Avatar
7 Second Club
thanks!
thanks, that was on an ls3 and 23ish psi the most that turbo ever made on my car was 26psi and it went 8.0@163 but the da was up 2000’ from the previous 8.0 pass
Old Jun 16, 2020 | 09:49 AM
jester1's Avatar
Forgot to ask but are you still rpm limited, or did you manage to wind it out some?
Old Jun 16, 2020 | 10:44 AM
Forcefed86's Avatar
At 7200ish now. Assuming my .660 lift dual BTR springs aren't happy with .600/.575 lift cam. Going to shim them a bit and go after more rpm soon.
Old Jun 16, 2020 | 11:49 AM
SLOW SEDAN's Avatar
haha that would be terrible, we send those springs to 7500+ everyday. I've used the summit springs for 7800+ as well, no signs of falling off with either one.
Old Jun 16, 2020 | 01:16 PM
Forcefed86's Avatar
Do you guys shim them?
Old Jun 16, 2020 | 01:22 PM
ls3fox's Avatar
7 Second Club
I also run btr .660’s no shims going threw the traps at almost 8k
Old Jun 16, 2020 | 01:56 PM
Forcefed86's Avatar
Well that's good news wasn't looking forward to doing the work. Were you around 600 lift as well?
Old Jun 16, 2020 | 02:16 PM
ls3fox's Avatar
7 Second Club
.605-.614 so pretty close
Old Jun 16, 2020 | 06:38 PM
SLOW SEDAN's Avatar
No shims on either
