Help with misfiring
Old Jun 19, 2020 | 11:55 AM
N U's Avatar
N U
Default Help with misfiring
Hello I have a turbo 4.8 car has always ran perfectly. The other day I was just cruising around and started running lean then it developed a bad misfire. I changed the coil packs checked fuel pressure and put a ohmmeter on the injectors. I hooked a scan tool to it but had no codes.any advice?
its tuned on e85 .
Sorry it's very vague I'm very new to turbos any help would be appreciated.
Old Jun 19, 2020 | 12:11 PM
Z32_5.3's Avatar
I had a random mis fire issue on dyno before tune other day... turned out I cracked the porcelain on my spark plug when putting them in. Didn’t know. Ran fine under normal driving but would misfire at load. I didn’t even see the crack with plug out, my tuner noticed it.
Old Jun 19, 2020 | 12:18 PM
N U's Avatar
N U
Would bad plugs or wires cause it to lean out? Also every couple seconds it will clear up.
