In need of a turbo oil sump
Use this as a model to go by. Or look up 911 oil drip tank and buy a new one.
https://patrickmotorsports.com/produ...930-107-004-pm
Shouldn't ever be pressure in a drain, no need for high pressure lines. Large ID tubing and hose is better. I'd flare the ends and slip a 3/4 hose over it where needed with clamps. If you already have AN fitings, might look in to AN to barb type adapters.
What turbo? what size drains do you have now?
Why is this even needed? I've never seen this before.
5/8" Hose Barb to 3/4" Male Pipe (for vent hose)
3/4" JIC 3/4" NPT (To connect from tank to scavenge pump)
Square Brass Tube 1/4" x 12" (To make the tank)
1/2 in. Copper Pressure Cup x MIP Male Adapter Fitting (To connect from drain flange to pipe)
Brass Pipe Fitting, Class 125, Coupling, 3/4" NPT Female (To connect to tank and then thread in the 3/4 JIC fitting)
The one thing I am left confused with is how will I thread on the tank to the flange that isn't an NPT fitting? I feel like trying to tighten the tank to a NPT flange would be quite difficult given how tight of a spot it is in. Is there some sort of compression fitting or flare fitting that I can use so it's sort of like a swivel type fitting?
you could use a oil pan fitting with an o ring? The sandwich kind. or a 3/4 bulkhead fitting? It won't be under pressure so it should be fine.
I purchased a check valve with a 1psi cracking pressure which was the lowest I could find, however the issue is my problem doesn't exist on the pump outlet side. The only place there should be pressure that would allow the check valve to open is on the pump outlet side. The issue, I believe, exists on the pump inlet side where there's a tiny uphill path to the scavenge pump and I can't mount the pump any lower than it is now. I'm afraid with a vent there isn't enough/any vacuum to pull fluid through the check valve
What pump are you using ? And what turbo was it before, and now ?
A proper pump does not need to be low, mine is at the top of the engine and scavenges unrestricted twins without issue. And yes there needs to be a check valve or solenoid on the feed line to the turbo to prevent oil movement into the turbo after shutdown
I have read multiple times about the check valve on the feed line. I'd like to fix the smoking issue while driving before worrying about smoke on startup
And once again, you must have a valve in the feed to prevent the turbo getting saturated with oil after shutdown. Until you have done that, it will always smoke at least until all that oil has burnt away after a long drive.
