LS3/F body
Old Jul 24, 2020 | 11:32 AM
Twinturbski's Avatar
Default LS3/F body
Hello, Kinda new to LS and F bodys so just want to ask as ive been researching but nothing that 100% answers my question.
I have a ls3 out of a 15 camaro and want to put it into my now new to me 99 z28. It will be on holley dominator tho and a Huron turbo kit. My question is.... Do I need to swap over all front drive accessiories off of the ls1 on to my ls3? Ive seen that alot have said to do so with adapter harness hits but they are older threads. Using the Holley harness and what not I didnt know if I still need to do this? The only thing I can see is I need to swap out the ls1 oil pan, pick up tube along with the dip stick. But as far as the pulley, water pump, alt and all that I dont see why as long as its all ls3 or all ls1 correct?
Old Jul 24, 2020 | 04:53 PM
stevieturbo's Avatar
Fitting may be easier with your own accessories...but whatever works easiest for you.
Wiring loom will need to be intended for that engine ( only minor differences anyway )
Old Jul 26, 2020 | 05:29 PM
B Mitch's Avatar
Ls3 accessory drive from camaro protrudes further from the engine than fbody and may not package well with the huron kit.
Old Jul 26, 2020 | 05:38 PM
LS3 pulleys sit 25mm closer to the engine than old Camaro FBody.
Old Jul 26, 2020 | 06:19 PM
See thats what I thought too but others are saying camaro ls3 = truck spacing but thats not what I saw. I saw truck ,ls1,ls3 camaro then ls3 corvette from furthest out to in. 🤷🏻‍♂️
Old Jul 26, 2020 | 06:36 PM
Corvette and LS3 are the same AFAIK, which is 25mm closer to the engine than the LS1/6
Old Jul 26, 2020 | 09:21 PM
jordoza's Avatar
The ls3 from a 5th gen camaro like you have does have the truck spacing. The ls3 from the vette has the 25mm shorter spacing.
Old Jul 27, 2020 | 03:48 AM
So what is the truck spacing ?
Because I have a Gen5 Camaro water pump here and the pulley position is the same as my LS2/Vette/ inner position water pump. There is no way it would ever work with LS1/6 or anything further out.
 Michael S. Palmer
Old Jul 27, 2020 | 09:14 PM
jordoza's Avatar
All I know is set a truck balancer next to my 5th gen balance and they are the same spacing. Look at any of the bracket manufacturers like lsx innovations and they say truck and 5th gen camaro have the same spacing.
https://lsxinnovations.com/product-c...20supercharger.
Old Jul 29, 2020 | 10:43 PM
jordoza's Avatar
From what I can find balancer depths are
corvette 3 7/16 off engine or 2 1/8 on engine
4th gen camaro 3 13/16 off engine or 2 15/16 on engine
truck & 5th gen camaro 4 3/8 off engine or 3 11/16 on engine
Old Jul 30, 2020 | 12:00 PM
You seem to be implying a 5th Gen sits the furthest away from the engine ?
That would seem impossible with the LS3 water pump I have here.
Someones bound to have pictures or something somewhere.
Old Jul 31, 2020 | 11:07 AM
B Mitch's Avatar
Are you sure you don’t have a corvette pump? ATI lists the same part number for gen 5 camaro and truck balancers.
http://www.atiracing.com/products/da...s/damchevy.htm
With that being said, the gen 5 camaro pump may still be shorter overall than the ls1 pump with the way the pulleys are shaped, I really don’t know. But the belt is definitely spaced out further from the engine on gen 5 camaro vs fbody because the balancer has the same dimensions as truck.
Old Aug 2, 2020 | 03:39 PM
jordoza's Avatar
I will take pictures of my water pump and balancer since I have my engine out of my 2012 camaro right now.
Old Aug 2, 2020 | 05:09 PM
jordoza's Avatar
This is the balancer and water pump off of my 2012 camaro ss. As you see it agrees with the length and spacing I have posted already.
Water pump depth.
Overall water pump
balancer depth
balancer over all
Old Aug 2, 2020 | 05:13 PM
I'll check the pump I have tomorrow, and I'm sure I have a LS1 crank pulley lying about too.
Old Aug 2, 2020 | 09:07 PM
B Mitch's Avatar
This is off an ls1 fbody
