Slow Spool Billet 7875 1.25AR normal?
I recently upgraded from a T4 GT45 STD 69mm T4 1.05ar to the T4 billet 7875 1.25 AR
The GT45 spooled pretty quick, didn't have to go full throttle to get into boost and would start building boost quick - within a second. With this 7875, it takes a few seconds going practically WOT to build boost. Seems like it stays in vacuum so long. Another thing is the 7875 is dead quiet, you can't even tell I have a turbo anyone. No spooly noises
.I feel like this was a really bad upgrade lol the GT45 was perfect, tons of power and quick boost and was super cheap. Only reason I replaced it was because the GT45 broke some fins, probably due to heat / running rich
Texas Speed Cam 3726/3730 115+4; 232/240 .595/.609 115 LSA 111 ICL
Circle D 'street' Converter – 2600-2800 RPM
3.33 gears
11.1 AFR target
3 bar SD tune
Methanol injection
2.25" hot pipes to the T4
Power goals - Minimum 500 RWHP, max 650-700 RWHP
What sort of tune tweaking? I'm guessing timing. It's a big shame, I actually wanted a turbo that would spool faster than the GT45 - after searching posts, I saw everyone saying 7875 spooled faster than the GT45. Now that I think of it, I wonder if they were referring to the .96 ar 7875
Did you go with the EBay $270 billet 78/75? Or a vendor unit? I wonder if those $270 ebay clones are to good to be true. Or if they are the same as the vendors sell. Myself and 2 other forum members tried some 72/68's out a few years back and they were plain horrible! Was like the compressor/exh. wheels didnt fit snugly in the housings and they were super inefficient. Curious what the tolerances are like on those cheap 78/75's. (i've never had one)
It's a vendor unit, $800
between the slow spool, compared to the ebay GT45, and also how you can't even hear it, I think I'm going to sell this turbo and jump to something else
