Upgrading my S475 T4
That said if you need to stick with a T4, go with the S400 frame and 75-80mm compressor, what ever you can afford. Make sure to use the big 87/96 exhaust wheel and modded 1.25 T4 Borg exhaust housing. Makes for a mean little T4!
Id run a 4" downpipe and 4" electric cutout. Best of both worlds. Cheap and relatively easy compared to a true 4" back exhaust anyway. I like to run 2.25 crush bent garbage to a stock muffler. Any exhaust shop should b able to hook you up cheap.
Not to hijack the thread but what I have is s480 t4 96 1.25. my exhaust system is pictured above. It goes from 4 inch v band to 3inch back up to 3.5 through a race bullet muffler, I also put a 3 inch cutout on it. Do y'all think I am hurting post turbine flow? I really hate the way a open downpipe sounds so I want to keep this exhaust. Also that part I cut off I didn't like the neck down so I replaced it with a smoother 3.5 transition.
