Big HP aster bracket users
Old Sep 4, 2020 | 07:20 PM
SCott5's Avatar
Default Big HP aster bracket users
Where are the aster bracket users that are making 1000whp or more? I am seeing the C5/C6 bracket users making over 1000whp, but not really the aster bracket. Is there a limit to it? I have been thinking of switching to a C5 A&A Bracket, but if the bracket and 8 rib can handle making over 1k then I’ll keep what I have.
Old Sep 9, 2020 | 04:17 AM
Pimpium57's Avatar
We have made 926rwhp with a D1X Procharger w/ the Aster bracket. This was thru a TH400, steel driveshaft, 12-bolt and 28" tires on a Mustang dyno. Fbody/Aster bracket guys with 1K+ rwhp are very few and far between.
Old Sep 12, 2020 | 10:21 AM
NitrOmm's Avatar
830 rwhp @ 14.7 lbs. I say keep & give it a try.
Old Sep 15, 2020 | 10:18 AM
ramairetransam's Avatar
it can be done , get the cbm 8.65 crank pulley than you can run a larger sc pulley and less change of belt slip .
Old Sep 21, 2020 | 09:08 AM
SCott5's Avatar
I did have the 8.65, but after talking to a few 1100whp users they were seeing flex at around that power with the bigger blowers so I just cut my losses and took it off and ordered all new A&A setup with 10 rib that just came in and I will be mounting it up top and all I have left to sell is my current aster bracket and water pump.
Old Sep 28, 2020 | 08:07 AM
hellbents-10's Avatar
Did 900 on one with the 8.65" CBM pulley. It was having belt slip issues though.
