Fan wiring
Old Sep 9, 2020 | 04:13 PM
Brucey Pooh's Avatar
Default Fan wiring
OK this is gonna sounds stupid but I can't find a straight stupid answer.
2001 firebird lq9 single turbo build in progress.
Can I connect a single fan to the pre-existing fan wires?
There are 4 wires that will need to connect to 2 wires. The threads I read are just over complex conversions and the original diagrams.
Could someone please explain to me how to connect the 4 original wires that went to the stock puller fans to connect to the 2 wire single pusher fan. I'm struggling with this one.
Thanks
Old Sep 9, 2020 | 04:58 PM
93Z2871805's Avatar
Veteran: Air Force
The factory fans are 1 power and 1 ground per fan, low speed and high speed operate both fans simultaneously. IIRC, each fan is on a 40 amp circuit (they draw around 30-35 on start-up). If you were so inclined, you could use both power wires together and both grounds together to run them to the power and ground on your new fan respectively, or you could eliminate one set of wires altogether. How many amps does the new fan draw?
Old Sep 9, 2020 | 05:06 PM
It claims 17.7. If I cut out the other set of wires it will only run in constant low mode though, right?
I am considering grounding the black, blue, and gray, then just connect power and ground the fan. I'm not sure if that is gonna work right or if I will lose the hogh speed.
Old Sep 9, 2020 | 05:31 PM
93Z2871805's Avatar
Veteran: Air Force
No, both fans run in both speeds. If you were to disconnect one fan, your other would spin low and high as temp increases. 2 of your wires (one per fan) already go to a ground on the passenger side of the radiator support behind the headlight (at least it is on a 93-97), I would just cap off the second power wire and cap the second ground and leave it in the loom nearby as it could prove useful for troubleshooting down the road, then use the other 2 to power/ground the fan.
Old Sep 9, 2020 | 11:06 PM
dlandsvZ28's Avatar
I forget the color combination of the wires for the primary. When installing make sure to test first so the fan runs in the correct direction. They will run backwards, so dependent if your fan is a puller or pusher, connect the wires so the fan runs in the correct direction before installing.
Old Sep 10, 2020 | 10:05 PM
rel3rd's Avatar
I run a single Flexalite 16" pusher fan, stock radiator, stock plastic "ductwork" or whatever you want to call it.
I only use ONE of the factory wires, the "Fan 1" ecm ground trigger wire, to turn on a 40 amp relay, have both 12v power input leads connected at the stud on the fuse box at driver side front corner, the power out is hooked to fan, and fan negative is grounded to core support.
I didn't run any new wires from the ECM. I got the factory fan ground trigger off of the stock fan relay, right there in driver front corner, at the fuse box. I'd have to look to verify wire color...
Using a separate add-on relay, ensured that when fan is triggered ON, it gets full voltage and works at its maximum speed. I also run it for 120 seconds at shutdown. Car stays decently cool, even hotlapping at the dragstrip. On the street, works great.
I plan to eventually use the ecm ground trigger for " Fan 2", as relay ground for an external trans and/or oil cooler fan.
If I remember, I'll grab a pic or two tomorrow
Hope this helps.
Old Sep 11, 2020 | 03:11 PM
Ping King's Avatar
The F body fans run 3 relays that run the fans in series during low speed, or parallel during high speed.
You should be able to just use the low speed circuit's power wire, and a separate ground to trigger another relay. There are wiring diagrams for converting the Fbody fans to a single unit from Procharger.
