Ls9 blower On 2015 Camaro SS
Old Sep 16, 2020 | 12:18 AM
Darrell Mootispaw's Avatar
Default Ls9 blower On 2015 Camaro SS
Ok so I've managed to seal the deal and got a fantastic buy on an LS9 blower which also comes with a Lingenfelter snout and a couple additional pulley upgrades. Forgive me if im just not looking in the right spot but I cant for the life of me find any successful installs where a parts list has been compiled. Also a majority of the threads that do mention it are from 2012 or earlier. Surely someone has some idea of how to make this work now. I need info on the accessory kit, cam suggestions. Fuel upgrade info, just basically I have the supercharger and intake, Need pointed in the right direction on this install. TIA
Old Sep 16, 2020 | 06:56 AM
old motorhead's Avatar
Go to the forced induction section of camaro5.com. I'm sure they can help.
Old Sep 16, 2020 | 06:58 AM
joyridin''s Avatar
Maybe start here? This can be a relatively easy swap because you can get everything from a ZL1 Camaro. I assume the Lingenfelter snout allows it to use a LSA drive set-up? You can start here:
https://ls1tech.com/forums/conversio...er-swap-3.html
Old Sep 16, 2020 | 06:08 PM
Pretty sure the Lingenfelter snout is a ported version of the stock snout. Maybe it's a complete new casting, but I'd bet it doesn't change the accessory spacing.
Old Sep 16, 2020 | 11:27 PM
Space's Avatar
The Lingenfelter high flow supercharger front cover is designed for the LSA equipped Cadillac CTS-V or Camaro ZL1 engines. This supercharger snout or front cover allows the installation of the General Motors LS9 TVS2300 supercharger without having to change accessory drive or air inlet location. The Lingenfelter LSA to LS9 Supercharger Conversion Front Cover features a high flow, low pressure drop design to increase power and airflow capacity. Fitting 2012-2013 Camaro ZL1, and 2009-2013 Cadillac CTS-V vehicles, the conversion front cover allows users to retain the OEM LSA accessory drive.
Looks like there are two snouts Lingenfelter made for ls9 superchargers. One to convert to lsa accessory drive and one that is a high flow version of the ls9. I don't think they offer the ls9 to lsa snout anymore though. So you need to check which snout you have to see if it is lsa or ls9 spacing.
Old Sep 17, 2020 | 06:41 AM
joyridin''s Avatar
Lingenfelter made a shout for LSA spacing. It was ridiculously priced. A lot of people bought them though. Even if he has the ported version, the snout can still have a pulley to use a LSA drive set-up.
Old Sep 17, 2020 | 01:43 PM
ADM performance has done all manner of adding LSA blowers to gen5 Camaros. I'd bet he's put an LS9 blower or two on gen 5's also. He may sell a kit that makes it a bolt together proposition. I know he does for LSA blowers.
