Bosch 210’s for a street car
They seem to cheap to be true. No leaking or tuning issues with these? I’m on ethanol and even though these are more than I need they are cheaper than anything in the 1300cc range that I’m looking at.
If you need a smaller set I thought the snake eater 1500's were about the same price as these?
I was told if I use the 829 model bosch 210 with the 10mm spacer it would be a direct drop in.
I currently have the magnafuel 25 micron post pump filter will I be fine with that?
So far budget options I’m aware of are:
Bosch 210’s
Snake eater 1500’s
After that it jumps up to deatschwerks which I currently use,but their 1500’s are $1500.
I’ve also read the 210’s are an issue if they sit with e85 because they are not stainless.
Any other budget options I’m missing? Something at least 1300cc at 43 psi for under $800?
Another option is to lower my alcohol content and add a cheap meth kit, but I’d rather not do that if I don’t need to.
241.69 243.13 244.58 246.02 247.46 248.90 250.33 251.75 253.17 254.60 256.01 257.41 258.81 260.21 261.59 262.96 264.33
So it sounds like your P59 is able to take the value if you're not getting that pop-up.
I think my deatschwerks 95 lbs per hour rated at 3 bar will handle a couple more psi of boost with 50 percent ethanol since I’m running 58 base currently then I may add meth injection on top of that. I still need to find something in the 1300cc range so I can run a higher ethanol content. Deatschwerks 1200cc are $1000 and would have me already near their limit on 85 percent alcohol.
I have a magnafuel 4303 with room so I think that for now I’ll bump up base pressure and that will get me by. Long term I’m looking at a bigger blower so I was thinking if I have to buy injectors anyway then I would size them for my long term goal.
For now it seems like bumping base pressure up a bit is a good option.
How does hptuners calculate duty cycle?
I just sold my 160lb LOW-Z Holley injectors. I ran an injector driver on these and they did NOT want to idle below 5% DC. I was right around that area on E85. They wouldn't idle pump fuel well at all. Some of that could have been the driver box.
I’ll need to do bigger injectors when I go to a bigger blower, but that could be a year off or at least a few months lol.
