Project Hornet is finally started
For some reason the temp & MAT sensors are way off, more concerned about the temp, so I didnt run it long. The valves are a little noisy, I had the lifter preload on the light side, so I will pull the VC's, verify oiling (had 52 lbs pressure) and install my 7.375 PR's (has 7.350's now). Need to work on the brakes before I can see if the trans works, always helps to be able to stop, lol. Prob need a good solid days work to neaten up the wiring, but overall pretty happy with the progress.
For now no IC'er, just plumbed from turbo to TB, still on the fence what to do there, might run some kind of closed A/W setup, room is tight. I run 93, no E85 around, also thought about meth spray, not sure how good distribution is with a liquid in an LS6 intake made for air, lol.
It really cruised pretty well, was comfortable, exhaust was quite (cant say the same for the rear, lol). Pretty happy with the smaller cam, was able to lock the converter in the upper 40's MPH, still run smooth. Prob. an upgrade to the something like the Summit "ghost cam" would still be doable.
Yesterday I pulled the front brakes off, had the rotors turned, got new calipers, pads (strange, got the correct calipers, but the listing for pads was wrong, ended up with pads for a Ford, lol) so brakes are back together.
Since Summit was at the show, snatched some cats. for the 10% coupons, so ordered a 9" Strange center section, tired of fooling with mine, lol.
Only other problem was the fuel tank vent, on a fill up it spit the fuel out the vent tube underneath, so going to make a small tank, mount it up high underneath, attach the vent hose to the low side, vent the upper side. Works kind of like a radiator overflow tank, used this setup before.
MAT's were around 140, about what I expected rolling around 65 MPH @ 2K, I imagine if I had an A/A would have been lower. I'll work on that one day, lol.
