Single turbo ls
Old May 19, 2021 | 09:05 AM
Rscaamaro's Avatar
Default Single turbo ls
using a f body ls1 assessory drive on my single turbo ls swap. The belt always walks a cog or 2 on hard pulls. Whats the fix
Old May 19, 2021 | 01:48 PM
mightyquickz28's Avatar
I would suspect you have a slight alignment issue with one of your pulleys.
Originally Posted by Rscaamaro
using a f body ls1 assessory drive on my single turbo ls swap. The belt always walks a cog or 2 on hard pulles. Whats the fix
Old May 19, 2021 | 02:35 PM
Rscaamaro's Avatar
my first turbo ls, didn't know other had issues with ls belt jumping on high horse power applications. I see lot of people running solid belt tensioner?
Old May 19, 2021 | 06:14 PM
Certainly, that's what I'm running . Not so much because I want to but because of the fitment of the turbo/componentry, I didn't have an option for a traditional tensioner. I've seen videos of the front of the engine when people dyno with the automatic tensioners and those things were getting a workout.
Old May 19, 2021 | 06:36 PM
ddnspider's Avatar
Katech manual tensioner.
Old May 19, 2021 | 09:13 PM
3 window's Avatar
I run all gm parts (water pump, tensioner, balancer) and my belt would move 1 rib forward after hard hits. Come to find the tensioner needed to be spaced out a bit. No issues anymore. Throw a straight edge across the front of all the pulleys and see where you’re at.
Old May 20, 2021 | 10:33 AM
Forcefed86's Avatar
Its not the tensioner or the HP. The pulleys aren't aligned properly if you are throwing/walking belts. A factory tensioner in good shape will hold a belt past 8k easy. Trying to band-aid fix the problem with a manual tensioner isn't the answer. I like to use TIG welding rod to drop in the grooves. Its pretty easy to see a misalignment this way. Good luck, it can be a real pain!
Old May 20, 2021 | 12:53 PM
SLOW SEDAN's Avatar
$60 version has held 8500 RPM just fine.
Amazon Amazon
Old May 20, 2021 | 02:10 PM
ddnspider's Avatar
$60 version has held 8500 RPM just fine. https://www.amazon.com/Manual-Tensio.../dp/B077PL3VPD
mine was $0.
Old May 20, 2021 | 02:25 PM
Forcefed86's Avatar
I had some issue with a straight edge as the pulley face to 1st rib isn't the same on all pulleys. Not that it can't work, but I fought mine forever with that method. I couldn't see how bad mine was until I laid (tried to lay) a few welding rods across the grooves.
Old May 20, 2021 | 04:55 PM
SLOW SEDAN's Avatar
mine was $0.
Link to free Katech stuff?
Old May 20, 2021 | 07:13 PM
ddnspider's Avatar
Sorry can't help you.
Old May 21, 2021 | 10:14 AM
SLOW SEDAN's Avatar
Exactly, to everyone else they cost real money.
Old May 21, 2021 | 11:17 AM
ddnspider's Avatar
I Agree. Just like a Holley Ecu. Deals to be had with anything. Time isn't free either.
Old May 21, 2021 | 11:49 AM
SLOW SEDAN's Avatar
Could run a carburetor!
Old May 25, 2021 | 04:48 PM
Game ova's Avatar
Blow through carbs ain't cheap either......
