Wastegate woes( Cortex EBC installed)
I suggest drilling a tiny little bleed hole in the line going from the top of the gate to the Mac valve. You may not need to do this, but the jgs gates are high quality and I expect little leakage with their design. The bleed hole will give the boost in the line somewhere to vent when the Mac diverts to the bottom port.
Mac valve is just a flow diverter valve that you can pulse to get a desired amount of flow between the ports.
Or just use this for a higher range but easy control.
Going to try this setup, see if I can get a better range . I did try this setup before I had an electronic controller and just used a plastic barb with a hole drilled into to make a stable 18 lbs tapering off to 14 lbs near redline with a relatively light spring
So I tried switching the hoses around and viola I have full boost control .
So my guess is as above mentioned by stevie turbo is that the wastegate being a quality piece seals very well and needs a vent . If I were to make a small vent at the hose going to the bottom on the wastegate and I'm pretty sure the very first method mentioned in this thread would work very well as well. The problem is the pressure between the top bottom of the dome is always equalized hence it doesn't matter what I do with duty cycle .
Now with the first method if the lower chamber was leaking putting dome pressure would give me more boost , which it did not . Because there was always pressure at the bottom chamber pushing back on the dome pressure .
But this all theory, I'll try both methods vent the top first and vent the bottom to see what results I get.
I had a 3-4 lb. spring with my EBC to dump boost in the event of a lean spike but (and I'm assuming) the back pressure in the system would cause the gate to open prematurely in the lower gears causing me to not see any boost until top of 3rd and 4th gear.
After installing a higher base springing in the 7-8 lb range I could then control boost with the EBC.
My guess was there was too much BP in the hotside, again this may not be applicable to what the OP is dealing with but I thought I'd share it anyways.
