Boost induced valve float?
Old Nov 20, 2020 | 07:52 AM
  #41
BCNUL8R's Avatar
Originally Posted by Kfxguy
maybe. I wasn’t looking at my afr gauge do that’s a mystery to me too. It’s usually in the low 11’s, high 10’s at 22lbs so hopefully it was in that area. I’m gonna make some time this weekend and get the heads off. I’ll start draining coolant tonight. That’s my most dreadful thing of the whole process. I’m trying to think what I can do while it’s apart to make things better. Might get the proper bore size gasket. Right now I’m running ls9 gaskets. I was trying to find some used head studs too.
Yep you’ll know more when you get the heads off. I’d check your timing chain like mentioned above as well just to make sure nothing weird happened there. Hopefully a valve didn’t stretch enough to make contact and new valves are all you need.
Old Nov 20, 2020 | 03:47 PM
  #42
SCLT1's Avatar
BCN- I live in the south and it’s a PickNPull place and it’s busy 6 days a week nonstop and they have been there since early 90’s and have a awesome rep and give you 30day free returns even on engines. I’m still working on it.
Old Nov 21, 2020 | 08:51 PM
  #43
Kfxguy's Avatar
Ok who guessed tuliped valves? But get this, the intake side tuliped. I think I know why tho. I’d rather not say why, to be honest.
I bought some $58 “stainless” valves off eBay because I couldn’t find ferrea at the time, or maybe I was being cheap. I guess I should have at least bought a name brand. I did it to myself. AGAIN.
Old Nov 22, 2020 | 01:08 AM
  #44
freeky's Avatar
now you know the limits of ebay valves
Old Nov 22, 2020 | 06:02 AM
  #45
BCNUL8R's Avatar
See post #3 LOL...it was an educated guess :-)
Old Nov 22, 2020 | 07:29 PM
  #46
Kfxguy's Avatar
yep. You were right.
should I.....
put stock intake valves back in?
put ferrea valves in?
ferrea hollow stem?
or manly race flo?
or these? They state that are coated and for high temps.
https://www.ebay.com/itm/LS1-Chevy-2....c100005.m1851
Old Nov 22, 2020 | 10:32 PM
  #47
ls3fox's Avatar
7 Second Club
Glad you figured it out and either put stock ones back in or manleys or something like that don’t go no name again
Old Nov 22, 2020 | 11:26 PM
  #48
ls3fox's Avatar
7 Second Club
Repost
Old Nov 22, 2020 | 11:38 PM
  #49
Kfxguy's Avatar
I hope you guys don’t mind. I’m going to create another thread about these cheap chinesium valves, warning people do not use them with boost. They would have been ok for a while I guess in a na application, but the face that contacts the seat was showing wear already. So I’d say the metal was way too soft.
Old Nov 23, 2020 | 11:47 AM
  #50
stevieturbo's Avatar
Ferrea, REV, Manley, stock.....as long as it's some decent brand.
Although I'd say the tuliping could also be lean, heat, extended hard use etc..
Old Nov 23, 2020 | 11:57 AM
  #51
SCLT1's Avatar
I agree with either stock or brand name don’t go flea bay again!
Old Nov 23, 2020 | 12:05 PM
  #52
Kfxguy's Avatar
but would you say the failure was more a result of being a cheap valve, because the intake side did it and the exhaust valves are ferrea. I would think the exhaust would definitely be hotter....
Old Nov 23, 2020 | 12:14 PM
  #53
The exhaust will be hotter...but it's also a lot smaller, and a damn sight stronger.
I've tuliped intakes myself, but that may be one of the risks in pushing too hard on pump fuel and sustained hard use...ie mile sorta thing.
On pump keep it on the richer side, keep timing sensible etc etc. There are just no benefits from trying too lean, or too much timing. And by too lean I mean even mid 11's, unless it's very low boost
As to whether there are potential valvetrain causes or not....maybe there are some factors there too, but not that I can think of.
