How do you size a BOV?
Old Nov 20, 2020 | 11:33 AM
SteveJewels's Avatar
Veteran: Navy
Default How do you size a BOV?
What is the correct size BOV? LS3, CSC, 13 PSI of boost. Cam, headers, 3" exhaust, M1 meth, , 4L65/70E, 705 WHP.
Thanks!
Old Nov 20, 2020 | 01:32 PM
V8sounds's Avatar
50mm should do fine
Old Nov 21, 2020 | 08:07 AM
Jimbo1367's Avatar
Who built the 4-L65/70E to withstand
700. RWHP? Must of been crazy $$$$$$
Old Nov 21, 2020 | 01:07 PM
Veteran: Navy
@Jimbo1367
More expensive than you think.
The entire drive train is built to handle a minimum of 1,000 WHP.
RPM Level VII 4L65/70e trans (deep pan, billet 2nd gear servo, HD 2 - 3 shift valve, billet input shaft, billet pump rotor, billet forward piston, billet overrun piston, micro-polished internal components, 300m output shaft)
Billet 8620 heat treated cone for automatic flexplate assembly, SFI flex plate, RM-8035 scatter shield bellhousing, Precision Industries 3,200 stall TC, PCS TCM-2000 trans controller, B&M trans cooler
RSD line lock
DSS 1,000 WHP propshaft, DSS Urethane couplers
RPM Level IV diff with Quaife gear torque biasing LSD, 3 series rotary for diff (Z06)
DSS RA5302X5 300M Level 5 1,000 HP axles
It was not cheap! I had the good fortune to buy it already built. I have a bunch of receipts. It is impressive.
At least I don't have to worry about the drive train.
