New build for 2021
Old Mar 23, 2021 | 12:00 PM
  #61
yenkomike's Avatar
Car is up and running. Any of you guys done the dial a boost with your gold box?
Old Mar 24, 2021 | 11:25 AM
  #62
Pro Stock John's Avatar
LS1Tech Co-Founder
Community Influencer
Nice project there. Weldon 2025 + roller sounds familiar, was that Lance's car?
Old Mar 24, 2021 | 04:08 PM
  #63
yenkomike's Avatar
That’s not who I got it from but it changed hands a couple times. Was from the Chicago area.
Old Jun 3, 2021 | 05:40 AM
  #64
yenkomike's Avatar
well after fighting with fueling issues and having a hell of a time getting it to do what i wanted i figured it out. it took me a good 3 weeks to find my 210 bosch injectors had crap in them . i run twin pumps and twin 30 micron filters but the crap was getting thru them . i had to ad a 10 micron filter to keep them clean. i never got to the dyno so i street tuned it added fuel and went to the track . for a safe place to tune. ran 10.81 on 11 psi and low 10 afr first pass went another 10.80 all the same but less fuel. added 2psi boost and pulled fuel thinking my second fuel pump was over powering my regulator but its fine and it went 10.49 at 127 still high 10 afr and that is all i ran due to a big bracket race that day. happy so far. i think that 12-13 psi will go 10.20 when my afr are in the upper 11s
Old Jun 3, 2021 | 05:43 AM
  #65
yenkomike's Avatar
Old Jun 3, 2021 | 08:31 AM
  #66
3 window's Avatar
I would ask how you like the 17-0 converter, but you’re not even close to the power you’ll end up at. Nice work Mike. Keep us posted.
Old Jun 3, 2021 | 09:41 AM
  #67
yenkomike's Avatar
17-0 works well even at low boost it will hit my 3900 rpm 2 step as fast as I push it to the floor. But feels good up top . 10.49 pass was 5400 rpm max lol
Old Jun 3, 2021 | 09:50 AM
  #68
3 window's Avatar
Mine’s the same. Comes on the chip like it’s in neutral and is super tight even at the top of low gear (1.80 glide). Are you footbraking it? How much boost can you make on the two step?
Old Jun 3, 2021 | 10:54 AM
  #69
yenkomike's Avatar
By the time I stage and the lights come down I’m at 7-9 psi so I was waiting to floor it as I wanted a 5-6 psi launch to hit it easy. I think it whould go to gate 11 psi in a couple seconds if I wanted.
Old Jun 3, 2021 | 12:15 PM
  #70
3 window's Avatar
Footbraking it or do you run a transbrake?
Old Jun 3, 2021 | 12:57 PM
  #71
yenkomike's Avatar
No I have a trans break. I might try foot breaking with my 2 step any see how it works
Old Jun 3, 2021 | 09:14 PM
  #72
Bad Apache's Avatar
Great outing!
Old Jun 4, 2021 | 09:17 AM
  #73
68roadrunner's Avatar
car looks great! what do the buick purists say?
Old Jun 4, 2021 | 09:27 AM
  #74
yenkomike's Avatar
Some wine a bit . But it was a roller so it’s not like I killed it. Faster now anyway.lol
Old Jun 10, 2021 | 11:27 AM
  #75
rt338b's Avatar
Nice outing Mike. I have had issues off and on with the 210s also looks like I need to put more filtration to it. Have only ran once locally but went 9.70 143 on 18lbs. Need to be able to leave harder as I am leaving on 2lbs for a 1.39 60. Need to compare notes as we have damn near identical setups.
Old Jun 11, 2021 | 05:24 AM
  #76
yenkomike's Avatar
thanks . i have a few things to get handled on the car and then i can get at it with some real boost. i want to add i dial a boost and get it on my buddy's dyno and get the tune right.
Old Jun 12, 2021 | 09:28 AM
  #77
Jwooky's Avatar
Awesome results, congratulations.
