Proper intake manifold sizing - gift from Santa
Just looking at some of the arguments and seeing things all together as a package. Obviously we'd all like to have the most efficient combo, but when it comes to the 1200 and below street car and $$$ more boost seems to often be the cheapest/best option. I saw a guy with a $20,000 motor make 1000 rwhp with 8 psi which was cool, but does anyone care if it takes 15 to 20 psi to make that goal?
How many people show up with 241 heads and a complete stock top end and run 9’s? That messes with their heads too lol.
One guy I know has a $20,000 427 making over 1000 rwhp on 8 psi another makes 1000 rwhp with a 5.3 on near 30 psi. Of course we’d all rather have the 427, but when money is a factor boost is only a number whether it takes 8 or 30 psi to achieve the number.
78mm to 9xmm is more than enough TB wise. The larger you go on the TB, the less control you have over the engine at slight throttle openings. Huge TB's move a TON of air at very little throttle opening. So they can make for a twitchy street car.
"1000 HP street Cars" seem to be the new thing. Entry level turbo guys need to realize there's no such thing as a 1000hp street car. Guys that run those power levels or higher have the power ramped WAY down so get the tire planted until they hit 100mph+ in most cases. I'm around 375 WHP till 50ish mph and slowly ramp in 700ish HP by 90mph to keep a drag radial planted. Even then the tires are fighting to stay planted on typical dirty road surfaces. A better setup car and suspension with larger tires can do much better obviously, but but the point is 1000whp is a $hit ton. And takes serious power management to make even remotely safe on the street. Unless you just want to spin the tires (which can be done with 500whp very easily).
Aside from the expensive and weak long runner FAST manifolds, what intakes out performs the stock truck TBSS/LS6 up to 6500? I haven't seen one... REC port heads and the stock LS3 intake seem to be the way to go on a 6.0 to make power cheap on factory parts. Though the cost of a rec port setup VS a cathedral is pretty high considering I paid $50 for my last set of 706 cath. port heads.
As mentioned, I too prefer to get the most out of my money. Stock parts and lots of boost is the way to do this. Going fast on little boost is simply a matter of $ spent. Yes, an NA 600hp motor can make 1000hp on 10lbs. Let's add up what a 600HP NA motor costs to build compared to a cam only 4.8 doing the same thing at 25-30lbs. The turbo is already there, size it to do the majority of the work. IMO, the whole purpose of having a turbo car is to let the turbo do the work. Why go through all the trouble of adding a power adder to have it do so little work? IMO, A 350hp NA engine making 1000hp in boost is much easier to drive/manage on the street than a 600hp NA engine making 1000HP in boost.
That said... nothing against big boost on big $ motors! Just not friendly street turbo cars and not in my budget personally.
Aside from the expensive and weak long runner FAST manifolds, what intakes out performs the stock truck TBSS/LS6 up to 6500? I haven't seen one... REC port heads and the stock LS3 intake seem to be the way to go on a 6.0 if you want to make power cheap on factory parts. Though the cost of a rec port setup VS a cathedral is pretty high considering I paid $50 for my last set of 706 cath. port heads.
As mentioned, I too prefer to get the most out of my money. Stock parts and lots of boost is the way to do this. Going fast on little boost is simply a matter of $ spent. Yes, an NA 600hp high compression big bore motor can make 1000hp on 10lbs. Let's add up what a 600HP NA motor costs to build compared to a cam only 4.8 doing the same thing at 25-30lbs. The turbo is already there, size it to do the majority of the work. IMO, the whole purpose of having a turbo car is to let the turbo do the work. Why go through all teh trouble of adding a power adder to have it do so little work?
That said... nothing against big boost on big $ motors! Just not in my budget personally.
On a side note what is the weight difference of some of the cast or sheet metal intakes compared to an ls6 intake? Not that it’s a big difference or determining factor just curious. Some of those monstrous high rams have to weigh more. Just looking at some of the arguments and seeing things all together as a package. Obviously we'd all like to have the most efficient combo, but when it comes to the 1200 and below street car and $$$ more boost seems to often be the cheapest/best option. I saw a guy with a $20,000 motor make 1000 rwhp with 8 psi which was cool, but does anyone care if it takes 15 to 20 psi to make that goal?
I agree nobody really cares how much boost you run, generally people are only shocked when its super low or its super high on a SBE and the engine stayed together. To me its just more of a personal goal because its super easy to make a bazillion horsepower on high boost, so for something new trying to make it on lower boost with better parts.
Then, hopefully, you can achieve your goals with about 10psi.
If the turbo and cam are sized correctly, the turbo should be about tapped out by the time you run out of cam. Even a bigger cam won't extract anything else from the turbo, and a bigger turbo won't get much more without a larger cam... perfection.
Like a system that was planned for a set goal.
E85 changed the game IMO. 20 years ago your 10lb theory on pump gas is probably a very sound one. Now we can run 30-40lbs (if setup correctly) without detonation on $2 fuel.
I agree not to over turbo your setup to the point the car is lazy and not fun to drive. But if your end goal is say 900hp and your adding a turbo anyway... why spend the extra money to reach the 450HP mark NA? Why not buy the cheapest motor (a 4.8) and run the "correct sized" turbo to hit your power goal? I routinely see Gen4 4.8s for sub $300-500 here. A small cam and S475 will make 900hp+ with good fuel. Yet a 450whp 4.8/5.3 would cost 3-5x the money to build.
Something about "just add more boost" doesn't sit right with me. I truly believe that less is more.
Just because you can make the same power with a less optimal combination, doesn't mean you should. Lots of people destroying perfectly usable engines, just because they can.
Well, not everyone has the money to build a 500hp naturally aspirated motor before adding boost if they want 1000hp... to that, I say, maybe those broke-@$$ b!tches can't afford 1000hp then. I can't afford an airplane, so I don't make goals that involve flying, sort of thing... Oh, but they can afford to do it half-@$$'ed, and that's fine for some people. To each their own.
I view boost as a piece to a puzzle, not the whole picture. If I can't afford to build a naturally aspirated engine, and I have to use a stock longblock... then my goals adjust accordingly.
Pick a reasonable cam to stab in there, see what it makes... aim to double that. Even a 4.8L with a trip-12 cam will be over 600rwhp with a mild single. 600rwhp is WAY more than, like, 80% of everyone knows how to sensibly handle.
Money aside... Compression is less efficient at making power than boost, this is a fact. The higher you'll go compression wise the more peaky your cylinder pressures will be at PK TQ and the more likely you are to hurt something. Higher compression narrows the tuning window. Makes it harder to keep the heads down, and the bottom end together as well. Where as lower compression and more boost will give you a wider tuning window, more average power, and less peaky cyl pressure. If money weren't in the picture, the correct answer is to find a happy median between the two. To arbitrarily limit yourself to 10lbs is shooting yourself in the foot for no reason. Look at the biggest names in turbo drag racing. Guys with 600+ cu inch proline blocks. Do you think money is a factor for them? Do you see them running 18:1 compression and 10lbs? There's a reason for that. What kind of static compression do top fuel cars run? If they could go quicker with more compression... don't you think they would?
Then we have to factor in streetability. If the goals 1200hp... How street friendly is a 12:1 600+hp 408 VS a mild 5.3? I don't see running more boost on a mild motor as any sort of a short cut is my point I guess. As you say... to each their own.
Money aside... Compression is less efficient at making power than boost, this is a fact. The higher you'll go compression wise the more peaky your cylinder pressures will be at PK TQ and the more likely you are to hurt something. Higher compression narrows the tuning window. Makes it harder to keep the heads down, and the bottom end together as well. Where as lower compression and more boost will give you a wider tuning window, more average power, and less peaky cyl pressure. If money weren't in the picture, the correct answer is to find a happy median between the two. To arbitrarily limit yourself to 10lbs is shooting yourself in the foot for no reason. Look at the biggest names in turbo drag racing. Guys with 600+ cu inch proline blocks. Do you think money is a factor for them? Do you see them running 18:1 compression and 10lbs? There's a reason for that. What kind of static compression to top fuel cars run? If they could go quicker with more compression... don't you think they would?
They we have to factor in street ability. If the goals 1200hp... How street friendly is a 12:1 600+hp 408 VS a mild 5.3? I don't see running more boost on a mild motor as any sort of a short cut is my point I guess. As you say... to each their own.
But you are absolutely correct about finding a happy medium for your tuning window. I don't mean that you have to only run 10psi... but doubling your torque under 2bar usually means you are doing it "right".
At some point, displacement keeps the boost and rpms managable. Not everyone wants to spin their motor 10k+ rpms. Not everyone wants to deal with 45psi. Finding that balance point is what it's all about, in my opinion. Cramming more boost into a BS combo is not finding balance, it a bandaid for BS.
For me, at least, there absolutely is a right way and a wrong way to make the power one might want.
