Is a second fuel pump needed
Old Jan 1, 2021 | 08:38 AM
kward's Avatar
Default Is a second fuel pump needed
Just curious, is one Walbro 450 is enough for a 6.0, Precision 76/75, Stage 2 cam running around 12 lbs of boost on a street car? I installed 2 pumps in the tank with the intentions of activating the second pump when the boost hits around 5 lbs but not sure if I really need to worry about it, thoughts?
Old Jan 1, 2021 | 09:36 AM
SteveJewels's Avatar
Veteran: Navy
What HP level?
Old Jan 1, 2021 | 10:08 AM
GMCGreg's Avatar
Pump requirement is going to depend on a few things
- fuel used
- base pressure plus boost pressure
- any restrictions in lines and filters
- voltage at pump or pumps
The simple answer is at ~ 600rwhp stock decapped truck injectors, rails and early return style regulator all works with 1 450 walbro on pump gas
Old Jan 1, 2021 | 10:12 AM
GMCGreg's Avatar
Bigger injectors and lower base pressure should get you even further on same pump - there are some calculators on line
Old Jan 1, 2021 | 08:34 PM
Dragframe's Avatar
I took my car up to nearly 20 psi on 110, a single 450, and 60# injectors lol. I like to party lol
