Anyone loop their trans cooler lines? Any drawback?
It sounds like you have poor cooler circuit function from what you describe. Not cooling at idle in neutral ect
The glide pump and shaft combo is sensitive to this, what is your combo of pump/shaft/stator tube?
that thermoswitch on mine is 180* I beleive, on the inlet of the cooler
It is on the instant I stall the converter under power. I can make a full hit over 1200hp and in 2-5 minutes after cruising the fan has shut back off
I am lucky to ever see over 160 sump temp no matter how hard I .on it or how far I drive
This is with locked stator even in the converter
i run a full ring shaft and have excellent function
-thanks!
