Off shore Turbo reliability
The S400 frame stuff is pretty bullet proof as far as turbos go. You rarely see one fail if not mistreated. If you buy the real cast S480 I'd go for the 1.58 T6 housing for the extra umpth up top. Your talking 1000-1100whp for 8.7x @ 3400lbs. And that's assuming you can 1/8th mile decently.
I'm a fan of your work! lol... that's pretty darn contained if you ask me! I don't think its fair to base a products reliability on someone that is over speeding the unit. Was the gate pinned on those runs? I'm betting that turbo was WAY over it's intended RPM range. The fact that it let loose and the hub didn't explode is pretty amazing IMO.
Fastest manual LS car is running 7's with VSR 78/75's, they seem to be working fine under that pressure ~30lbs on a 427 if I recall.
I would agree, thats a pretty mild turbo failure. I had the same exact thing happen to a box stock borg, wheel is still sitting on my bar.
I'm a fan of your work! lol... that's pretty darn contained if you ask me! I don't think its fair to base a products reliability on someone that is over speeding the unit. Was the gate pinned on those runs? I'm betting that turbo was WAY over it's intended RPM range. The fact that it let loose and the hub didn't explode is pretty amazing IMO.[/QUOTE]
thanks man, on that pass it had 60psi on the dome so safe to say the wastegate was pretty much shut the whole pass so there’s no doubt I over spun it
it was a decent turbo for what it cost but in an apples to apples comparison with a real s475 I had 60psi on it for a lot of passes and it’s still perfectly fine
for the price of the gen 1 vs80 I don’t think you can go wrong just know that when it’s done don’t push it lol now if you were thinking of a gen 2 vs turbo I would be nervous about spending 1600 on one but that’s me
Not sure what VS turbo is $1600, must be a 106mm or something. But I'm sure that price beats spending $5,400 on a precision that lasts 3 miles, or $3000 on a comp that doesnt make any more power than a shelf borg.
I have been tossing around the idea of playing with one of the gt55 knock-offs to see how they do but idk if I wanna waste the money if it’s not gonna make more then my s491 does
Not sure about the knockoffs but we went from the S491 to a real GTX55 and made the same power on 10 less lbs, and continued upwards made a lot more on 32 lbs than the 491 did on 37lbs. To me the 491 is a stop gap if you cant get around the S400 sizing, but the GTX55 with a tial housing is a killer! Kinda funny when the GTX55 on gate traps the same as the 91 on kill. You can find used GTX55's for less than the knockoff units, thats my main holdup with paying over $1500 for a ching chong unit.
needing something larger than a s480 but didnt want to make the jump to a gt55 yet and have to redo the entire hot side. the 92/110 dropped right in place of the s480 and has worked pretty good for a few months now, grabbed from huron speed when they dropped to price another 100 on it . if a used bw s491 popped up for about the same price i probably wouldve grabbed it but wasnt interested in paying new price for one knowing in less than a year id want to go bigger.
https://www.on3performance.com/shop/...-housing-copy/
as far as the on3 big turbos go I think mavn has the 94 which needed like 28psi to crack 1k and I’ve seen another guy with the 107 that needed I think 36-37psi to make 1300 so there kinda crappy from what few I’ve seen
Complete street performance had one on a vetted awhile back and blew the intake up. if I remember right they where around 1300rwhp when they blew the intake up.
But I have also read that they don't make the power of a true gt55 106mm but hey I'm really considering trying one myself.
