How often you empty catch cans
Old Jan 30, 2021 | 10:39 AM
jybravo70's Avatar
Veteran: Navy
I have been looking at catch cans recently and am not sure if it would be worth while for me. I have a bone stock 2002 LS1 that has the "fancy" intake that the CETA's were fitted with. The car just turned 45k miles. I am thinking about catch cans to keep the intake system clean and help keep the valves from gumming up. Are these only worth while for boosted/supercharged applications? Is it just overkill for the amount of benefit? Thanks!
Old Jan 30, 2021 | 12:14 PM
dlandsvZ28's Avatar
Remove the throttle body intake and look inside the intake. If it's reasonably clean and dry inside then perhaps not. On the other hand, if it's a mess inside, then IMO install a catch can but get a good one (MightyMouse catch cans have good reviews).
Tip: the LS3 driver side valve cover has a much improved baffle to stop air borne (suspended) oil inside the valve cover from being sucked into the intake (NA)
If you have some oil contamination inside the intake, you might try changing the driver side valve cover first and check results before purchasing a more expensive catch can system.
https://bobistheoilguy.com/forums/th...nstall.251305/
Old Jan 30, 2021 | 01:01 PM
QwkTrip's Avatar
Originally Posted by Jwooky
Hi thanks all for the feedback. To clarify, the following is my setup. They are GM performance valve covers that are baffled.
I recall now that the line to the Turbo inlet was not present during the dyno time. The oil cap (X) in fact blew off during the session.
Come on dude, why did you hold this information back earlier? Your PCV system can definitely use some improvements, but you might just have a lot of piston blow by.
What was the mixture like in your can? How much oil versus water? The oil and water should have separated out if you let it sit overnight. What do your spark plugs look like? Signs of oil? How much boost are you running and what HP did the engine make?
Old Jan 31, 2021 | 09:22 AM
Jwooky's Avatar
Sorry, certainly not trying to withhold any info. This was a few years ago now, and frankly a bad experience on the dyno. The guy actually ended up wrecking the car and we had some serious disagreements. He was supposed to be the a guro, you had to be recommended to him etc. he was an intolerant a$$hole. Anyway so to answer your question, I went there at ~17 lbs on spring, which was ~700 WHP from memory, and he insisted on removing a waist gate spring , which put me 10 lbs 525 WHP. It is a SBE LS1. I had intended to increase the boost to ~15lb, and get it re tuned, but haven’t yet. It’s pretty sketchy on street tires even at this level.
It seemed like mostly oil to me, but it would have remixed when I drained it. I honestly did not pay the at close attention. Had it not been dripping I wouldn’t have even noticed it. I have not pulled any plugs. It runs great, not smoking at all.
I am leaning it filled on the dyno, when the line was removed but just not sure. I plan to monitor it this summer when I get it back out. It was in the body shop almost all last year after the dyno.
I will still welcome any critique of the PVC setup, if there are concerns. Based on my research here, and elsewhere, even OEM boosted solutions, it seems like a classic setup.
Old Feb 1, 2021 | 08:12 PM
GMCGreg's Avatar
Strictly a FWIW post here , my set up is this
home made catch can with 2 check valves
Factory orifice on drivers side VC drilled out to max size bit i could get in there , basic sbc gen 1 pcv valve adapted to cover with a few sizes of hose
3/8 hose to bottom of can ( below filter medium )
2 check valves in top of can, 3/8 hose to intake ( Factory pcv port )
another 3/8 hose to pre turbo / post filter
pass side VC port 3/8 hose to pre turbo/post filter
Under boost or WOT both covers get a slight vacuum from air filter restrictions -- haven't measured but it works well
this set up worked well but got a lot of oil - 3-4 oz per tank of fuel . Was a real pain on HRPT.
As mentioned above gm revised the valve cover baffling a couple of times, there are pictures on line so I basically copied what I could to my 04 covers by rtving same thin material over some of the holes and making shields around others . I did both covers as it vents out of both at Wot that change reduced oil in can by 2/3.
other factors , ring gaps are unknown 180k un opened, pump gas WM injection 15lbs max. No dyno but about 600 rwhp from calculation. No open vents as you can get a 300+$ fine for that around here . As far as I can tell just oil in the can , a bit darker than what's in the engine
Old Feb 7, 2021 | 08:51 PM
jybravo70's Avatar
Veteran: Navy
Cleaned my throttle body tonight, it was filthy and seems like it first cleaning in a decade, I tried to take a peak inside the manifold, it looks like varnish and some glistening but I can see shiny bits here and there, is this normal? I will work on the ERG valves next. I might get a USB light to get into the body to see if there is any liquid or just varnish inside.
Top looks pretty dirty
I can see some of the back
Was able to get some reflections off of the interior
