5.3 best head gasket for boost?
#61
I stopped watching when he said that. Watching AFR only is stupid. Last time I checked an O2 is going to put out a number regardless of how many cylinder feed the exhaust tube. And the more cylinders feeding the tube the more 1 cylinder can be off but minimize the impact of the average.
The following 3 users liked this post by SLOW SEDAN:
#62
#63
#66
#67
That was a decent topic I was just talking to a friend about the other day. It really is interesting especially when comparing turbos and *gasp* if they actually have a compressor map
#68
The following users liked this post:
SLOW SEDAN (02-09-2021)
ls13ater (02-09-2021)
#70
The compression things always a trade off. Your just trading response for more power making potential. Think most are at he point where they know the more you make NA the more you make in boost. But the 4-6% rule is pretty standard per point of compression. Which is then compounded with boost. So if 1 point of compression picked up 5mph at the same boost... what happens when you run 5 more pounds of boost instead with the 317's? Why is one better than another? Which will make more assuming your not turbo limited?
You'll have less peaky combustion spikes with lower compression and an easier time keeping the heads sealed if you really lean on it. A lot of that is in the tune, but tuning around peaky cylinder pressures isn't ideal either. Its been proven MANY times with the methanol guys running big boost. There's a point where it just makes sense to drop compression to keep the heads down. Where that is will depend on the application. There's a reason top fuel runs 6.5:1 compression ratios.
Low compression gets a bad wrap because its crap for spooling turbos and you need a larger power adder to do the same work. You also have to look at the lady finger VS M80 theory. A bigger CC is ultimately better and will allow more power... If you can reach your "goal" without stupid low compression and giant turbo(s) that's a bonus. Zero reason to go crazy in either direction IMO. I prefer to have just enough to get into boost quickly on the 2-step/brake. Once the turbo is making target launch boost... it didn't really matter in my experience. 8.6:1 VS 10:1 could net the same times by varying the boost levels. I'll say as a personal preference, I hate the sound of a doggy compression LS vs a nice crisp raspy 10:1+ I don't see any reason to be under 10:1 on an e85 build SBE either. I just like to stir up discussion.
If I were building a Bonneville car and wanted a stupid amount of power and response isn't a concern, I'd go with a "low compression" setup. Its just easier on parts all around IMO.
#71
There is a peak power range AFR for every fuel. IE run it on a load dyno at a fixed load. And adjust the timing and fuel for peak power at that load. He never mentions actual numbers... But sounds like his method of tuning is throwing too much fuel at tune then advancing timing (beyond MBT) to burn excessive amounts of fuel. This will result in higher cylinder pressures and less power. Its a great way to blow a head gasket. Going beyond peak power window of a fuel just to have more fuel in the cylinder does nothing for power. The guy's a half wit IMO.
Here's a great explanation as to why he's full of it...
https://www.innovatemotorsports.com/resources/myths.php
#72
#73
#74
Stop with your reason, drive top fuel cars on the street
ddnspider (02-09-2021)
tblentrprz (02-09-2021)
#76
I’d be better off building a purpose built car than destroying my low mileage GTO to try and remove 1000 lbs let alone 1500.
I haven’t ruled that option out yet although the wife would accept me putting a torque arm or 4 link in this irs car before she would let me start another project. A 315/60/15 and anti squat would be a big improvement over my 275/50/15 squatting irs even at the same weight.
ETA: I’ll still be staying with procharger no matter what I do though lol.
#78
#79
The 4 link is definitely superior for what I want to do, but moser makes an all inclusive 9” torque arm kit for the GTO so it’s the easier conversion.
#80
