Oil pump for twin turbo setup
Old Feb 3, 2021 | 09:48 PM
ls13ater's Avatar
I had a f body pan with baffles and 7 quarts years ago in a t56 turbo 5.3 mustang, with a f body cluster, it would throw the check gauges light on, well after 7 passes I figure out which gauge I need to check, it locked the turbo up (on3 88) and spun a bearing on a fresh built motor, it tried to lock up on the decel, 1.32 60fts, when I built my new car I used a 07 later truck pan, welded up the bypass valve on the pan, we run 8 quarts I been @ 1.15 60ft and it’s never gave me a problem I have a safety setup in the fuel tech if it ever does drop
