gen 3 6.0 max hp
thanks for all replies
You can make a lot more than that, but if your being quasi safe about it then just doubling the stock hp is probably what you're looking at.
You're easily going to break a gen3 rod before you the pass the pumps limits. The weakest link in your entire setup will be the rods unless you decide to use a 4l60e/th350 or something funny like that. I just got through hunting down an LY6 6.0L over an LQ4 just for this reason.
1. https://www.texas-speed.com/p-1016-t...-assembly.aspx
2. https://www.texas-speed.com/p-1159-p...-castings.aspx
Honestly though, if folks know your vehicle setup (all the details), application (street, reace, etc.), goals (hp, et. etc.) and budget, they can provide much better insight into what "they would do if it was theirs".
1. 4.8l pullout: 2200$
2. 5.3l pullout: 3000$
3. 6.0l pullout: 4000$
4. 8.1l pullout: 3950$ (this one is here for kicks and giggles
) 1200hp is not going to be reliable. 800 will be, but over a 1000hp and you're at the craps table with factory bottom end in my opinion. It makes that kind of power on an engine dyno, which is a lot different than throwing it down to a set of wheels. There are no jarring moments when the wheels grab hard or you get wheel hop or something. That stuff invites Uncle Rodney to the party and he arrives like the Kool-Aid man.
If you are shooting for 1200hp though, get the 5.3 with an iron block. Thicker cylinder walls, cheaper and easier to find, more used parts around for it like the pistons and rods. You can ebay gen4 rod sets for $100 for all 8.
I make my big power on a 5.3 with a the biggest single t4 I could find. I'm putting a 6.0 in the '68 c10 I just got because I'm going more of a 'sports car/truck" route with it with fantastic handling and brakes and probably a max of 600-700hp with gobs of torque in the 3k RPM zone. Truck cam, small twins or a 78/75 with a 2" hotside...make it spool up in a traffic jam lol.
