Water Injection Question
Old Mar 25, 2021 | 04:26 PM
  #41
LetsTurboSomething's Avatar
Aside from the invisible part... How's it any different than a gas fire? Yet we all run that on street cars daily. Just need to proper safety precautions IMO.
You'll always see more power with large amounts of meth. Its no different than switching to E85 and picking up 10% power on fuel alone. That doesn't mean meth pulls more heat at like volumes than water. Pulling heat from the CC isn't going to give you any performance alone. You'd need to adjust the tune for that. The big issue with water is you are extremely limited volume wise due to ignition issues. With methanol there is no real limit.
It's super corrosive compared to gas, volatilizes easier, don't discount the danger of invisible fire either. So it is actually much more of a hazard to have a container of it under the hood and coming out of a 200psi pump. But you're right, it's barely worse than running an extra fuel injector in the intake of a turbo setup like people did a lot 20 years ago when they couldn't change EFI tunes. Spraying raw fuel into the intake in the same manner that we do with the water/meth mix is dangerous as hell. Tons of it get pushed out all over when the blow off valve opens after you let off...Mines dyes the engine bay blue...that's all going to be potential fire with pure meth.
Old Mar 25, 2021 | 04:41 PM
  #42
BCNUL8R's Avatar
The invisible part seems to be a big deal though. I mean the sooner you actually know you are on fire the sooner you have to react to a bad situation. It seems lately with how fast "street" cars are that fires are becoming more common. It's definitely a concern for me. I keep a fire extinguisher in the car, but how much more can we really do in a true street car? How many people run fire suppression in a truly daily capable car or even a weekend toy that is still primarily a street car? I use quality steel braided ptfe hose and fittings with the coating over the steel braiding for my fuel system. Nothing is infallible, but that seems safer than a plastic push connect line with a flammable liquid in it doesn't it? I'm just saying if you are using meth in flammable percentages you should treat it like you would your primary fuel source. You don't run plastic push connects for your primary fuel system.
Cars that run straight meth as a primary fuel system run cool. I've seen some stuff on youtube where people run methanol cars on the street and don't even get up to full operating temp or have injectors in the intake and it frosts up.
I'm 100% bringing these things up to learn as I'm making decisions what direction I may go from where I'm at now.
Old Mar 25, 2021 | 04:47 PM
  #43
ddnspider's Avatar
Originally Posted by LetsTurboSomething
From what I understand the methanol is more to help it atomize faster because the boiling point and evaporation points are much lower than water. It's not really about the actual fuel the alcohol provides because in water/meth setups it's an insignificant amount of methanol as far as the AFR changes go.
Gasoline has a lower boiling point than water and comparable to methanol depending on octane. The methanol is providing an increase in octane. If methanol was removing all of the heat, nobody would run lower % of methanol to water, or water at all besides the fire risk. The phase change of water to a vapor is what is absorbing the majority of the heat.
Old Mar 25, 2021 | 05:05 PM
  #44
Forcefed86's Avatar
Its totally dependent on how much meth you run and how much performance you want out of it. I've seen 4 2200cc injectors pre turbo feeding over 500hp worth of Aux fuel cool 42lbs of boost down to 155ish* with no intercooler. The setup worked great. It also eventually turned into a giant bomb and blew his intake in half when the engine back fired.... But until then it was a worker! Need a burst panel and should use SS lines and good fitting on serious kits. Just like you wouldn't use push lock nylon with your fuel line.
BOV's are another topic with much debate. They aren't necessary in most cases and many don't run them. You could recirculate the BOV into the intake as many manufacturers do. Or you could skip it all together on most "drag" cars. I won't be running them. And I'll be spraying quite a bit pre turbo with no IC.
Old Mar 25, 2021 | 05:15 PM
  #45
ddnspider's Avatar
Now combine the 2 with people running meth pre BOV and people freak that you're bov is going to spray meth and 🤯 😂
Old Mar 25, 2021 | 05:20 PM
  #46
Forcefed86's Avatar
Also FWIW I've been spraying it for 15 years on many other cars with BOV's at 50/50 or higher and I've never had an issue.
Old Mar 25, 2021 | 05:23 PM
  #47
BCNUL8R's Avatar
I run my bov pre-intercooler and outside the engine bay down low behind the front bumper cover.
Old Mar 25, 2021 | 06:00 PM
  #48
ddnspider's Avatar
Exactly.
Old Mar 25, 2021 | 06:01 PM
  #49
ddnspider's Avatar
Mine is pre IC as well. Why send it through the heat exchanger to then dump it.
Old Mar 25, 2021 | 06:30 PM
  #50
BCNUL8R's Avatar
That was my thought, but also coincidentally happened to be where it fit the best...LOL. It was nothing to do with meth as I don't even use the stuff. I'm just looking to make big changes in the next year or so and trying to learn about all options at this point.
Old Mar 28, 2021 | 07:16 AM
  #51
Shownomercy's Avatar
Man-Crush Warning
As an update for my setup, pushed 16psi and IAT were at 120* so never needed to setup the water/meth
Old Mar 28, 2021 | 11:12 AM
  #52
Forcefed86's Avatar
As mentioned... Or as I tried to mention. The charge temps aren't the factor. you can have 80* charge temps and insane high cylinder pressure and temps. A lot depends on the tune. I can make 120* charge temps knock easily by adding too much timing. There's no reason not to run it, if you have it. Though if the plugs look great... no need to buy it if your happy with the power either. Think of it as having 105 octane in the tank, but only while in boost. Its just good insurance. Also if you can run 16 and the plugs look great. You can likely run 20 with it. So always something to think about.
Old Mar 28, 2021 | 11:19 AM
  #53
GMCGreg's Avatar
^^^ exactly, if you've got it might as well run a small amount just for insurance and to keep deposits which can cause knock down . What were your results ? Always good to know what different combos are making
Old Mar 28, 2021 | 08:19 PM
  #54
Man-Crush Warning
Yea I worded it wrong, basically was half expecting to see scorching IATs and knock, but did not see that, and IATs were comfortably low.
Timing is fairly conservative as well.
Old Mar 29, 2021 | 09:52 AM
  #55
forcd ind's Avatar
I was going to try and get away with no IC, mainly just a street car, but now that I can mont. temps, I did a little hit while data logging, @ a little over 7 lbs, it showed the MAT as 180. Some of it is prob coming from the rad., as it just goes from the turbo to the TB right in front of the rad. But it was wrapped. Looking at some kind of simple A/W setup, as room is tight. I was hoping to sub. it with some spray, but I think the temps might be to high.
Old Mar 29, 2021 | 10:16 AM
  #56
Forcefed86's Avatar
Are ethanol blends an option? FWIW I max out my IAT sensor before the 1/8th mile at 255*. No IC E50-E60 range fuel. 2 10gph nozzles pre turbo (twin 64's) at 19lbs. Plugs look great. Much less demanding on the fuel system to run e50 VS e85 and its still a VERY capable fuel. I'm on 80lb injectors still with room to go if I wanted.
Old Mar 29, 2021 | 04:11 PM
  #57
forcd ind's Avatar
Unfort only 93 around here.
Old Mar 29, 2021 | 09:28 PM
  #58
3 window's Avatar
Move. LOL
Old Mar 30, 2021 | 04:40 AM
  #59
BCNUL8R's Avatar
Damn it sucks to be heavy...lol. I’m at 90 percent duty on 1200 cc injectors with 50 percent ethanol. Base pressure 58 and no pressure drop. No water/meth though. Big air to air and my iat has never been over 120. I’m slower than you though...lol
Old Mar 30, 2021 | 07:36 AM
  #60
ddnspider's Avatar
Damn it sucks to be heavy...lol. ...
Amen!!
