Looking for insight
Old Mar 24, 2021 | 09:54 PM
shitbox's Avatar
Default Looking for insight
I built myself a turbocharged junkyard lq4 miata :] Its an absolute blast to drive.
Anywho, i want to throw some more at it and see what it can do at the drag strip
Specs:
Stock bottom end junkyard LQ4
Stock 317 heads
LS6 intake
colder plugs
hphv melling pump
comp 54-454-11 cam
btr hardened pushrods [oem length]
comp 26918-16 springs
78/75 vs racing turbo
no BOV
44mm vs racing wastegate
ebay charge pipe
ebay intercooler
truck manifolds flipped forward
single walbro 450 feeding a surge tank, twin 044's feeding the rails
ebay rails
ebay regulator
ebay surge tank
ebay lines
ebay fittings
car made 500whp/500rwtq on 11psi
13* of timing with and 42%idc. So, PLENTY of fuel left
SO, metallic miraculously got in the oil and now swapping to an '04.5 5.3 [with the better rods] before i grenade the lq4 [still runs great and doesn't knock].
I am purchasing headstuds and ls9 gaskets tonight...... how much more stress can i truly throw at this junkyard engine? I wanna shoot for 750-800..... if a rod goes then it goes.... its a $300 5.3 junkyard bomber with 200,000 miles.
but what is the "safe" range vs the "kaboom" range?
I was thinking about ~17psi and seeing what it makes?
File Type: mov
File Type: mov
Old Mar 24, 2021 | 09:59 PM
SLOW SEDAN's Avatar
My vsr 78 on gen 4 SBE didnt want to do much over 29lbs and seemed tapped on power at 24-25. Anything over 800hp is good for that little guy, some get near 900 with the next gen version.
cool build btw
Old Mar 24, 2021 | 10:05 PM
shitbox's Avatar
holy crap, 29psi?!
it sure is the next gen.
hmmm, you have built my confidence sir! lol
thanks
Old Mar 24, 2021 | 10:09 PM
SLOW SEDAN's Avatar
Originally Posted by shitbox
holy crap, 29psi?!
thanks
That was on e85, they generally have a pretty good life if you fuel them properly and don't get greedy with timing. Ive run more on sbe with larger turbos but of course the lifespan is shortened.
Old Mar 24, 2021 | 11:55 PM
LetsTurboSomething's Avatar
I run mine up to 17psi @ 10* all day long on a bigger turbo. You're no where near its worry point at 800 hp unless you have a bad tune.
Old Mar 25, 2021 | 11:30 PM
Pro Stock John's Avatar
LS1Tech Co-Founder
Community Influencer
Yeah just make sure you have the right plugs in there and enough fuel/injector for the boost.
Old Mar 26, 2021 | 05:27 PM
Traction setup is probably your biggest limitation to getting your fasted ET right now.
