How far to space FMIC from radiator?
1) Intercooler, a/c condenser, radiator, then fans mounted in a shroud. Many companies now use one piece condenser/trans cooler units.
2) The intercooler, condenser and radiator are sealed to one another so no air can go around them. If one has a smaller surface area, it will just be hanging in front of the next part in the stack.
3) The air coming in the front of the car is made to go only through the component stack. Shrouded/sealed around all 4 sides to direct all the airflow through.
4) The fan shroud has simple rubber "flaps" that hang shut at low vehicle speeds to allow the puller fans to do there job. Then as vehicle speed increases, fans shut off about 35 mph and the the force of natural airflow through the component stack forces the flaps open to overcome the fan blade induced restriction and allow maximum airflow.
Hope that all makes sense.
Leave at least a 1" gap between FMIC and cond or rad core to allow air to transition as needed.
Side note - covering open areas around rad to insure air is forced thru rad core is key for improved highway cooling.
All true but very few use the flaps anymore. Costly and not that helpful.
When fans are able to be off, they will just let it windmill.
Here are some examples of stacking cores:
This is off an 18 wheeler, notice the condenser is out front because the intercooler is so large. They are bolted together as a unit.
Gap between radiator and intercooler is fairly large but only because of the large dimensions and bracing for weight. The condenser has almost no gap.
This is off an Infiniti G37, integrated condensor/radiator setup to keep gap at a minimum and cover the sides to prevent air from escaping. This design is cheaper for the OEM but sucks for the consumer.
Mitsubishi Lancer Evo X, gap is at a minimum but intercooler mounts to chassis separately.
Mitsubishi Lancer Evo 8: huge gap between oem intercooler and radiator. Designed on purpose, turbocharger sits close to RH side of radiator. RH side has a chassis mounted pusher and LH radiator mounted pull fan.
Typical aftermarket shroud to block gap between condenser and radiator:
Ford F-series super duty 6.4 powerstroke, There is 6 different coolers on the front end from the factory:
Some pics of stuff I can improve (in terms of sealing off the front)
My FMIC and rad are 1.5 gap, helped by my aftermarket core support
No the exact opposite, the more gap between them the slower the air moves, the more resistance. The evo 8 literally has a fan between the radiator and intercooler because the gap is so large.
My STi had at least a 1.5" gap between the radiator and FMIC when I took off the condenser (when the car was still 4 cylinder). That is extremely common on WRX/STI/EVO and nobody except the time attack guys complain (600whp+ road racing).
edit: forgot to mention, but that setup doesn't have any gap on the bottom usually. the sides are blocked by the radiator support and the top usually everyone has some fancy shroud covering the rad support. The stock grille blocks some of the air on top.
Can you define necessary? 1/16", 1/8" or ~1"
Looks like a couple points being presented here. If you desire to use the rad cooling fan to pull air through the FMIC, seal the perimeter between the 2 assemblies. If you want max air flow through both assemblies you can't stack cores against each other since the core spacing is different. A smoke flow test will reveal the issue. Typical gap between cores is no closer than 3/4". Seal between the assemblies is key for air to flow through and not around the 2nd core.
You have to take into account how its mounted. Specifically does your intercooler move around? Is it mounted solid or rubber hangers?
Most intercoolers are shorter than the radiator anyway, and plenty of airflow hits the radiator.
Up to 2" gap won't cause issues on common size radiators but you have to block most of the air from escaping between cores, that is important.
The fin density, the gap between cores, intercooler centered perfectly in the middle, whether its 1" or 1/16" is irrelevant......unless you're trying to set records in Global Time Attack, NHRA, or you are trying to do 140MPH+ for longer than 10 seconds. There are other things you can do to help cooling.
Cliff notes:
Large gaps are not needed at all, but its OK if you have to have them.
1 inch gap or less is great.
I don't mean the small gap between them will keep the air from escaping. I mean around the whole stack, you want to put the cores inside a tunnel. Force the air to go through a core and its only exit is another core.
If you can't tunnel it then keep gap at a minimum.
