Opinions on different meth/spray kits
I don't race it, but may hit a rental or T & T now and then, but just playing on the street intake temps jump pretty quick. I run 93 octane, but have a FF sensor, although no E85 around. I would like to come up with a tune on like E50.
if my pump doesn’t work and safety timing is not enough then good chance my motor will open up. Glad I spent the money. I spray M1 so I’m dependent on the fuel portion not just air cooling.
The equalizer is suppose to solve the air distribution problems.
I run 50 percent ethanol and only a 3 gpm nozzle currently on at 3 psi. IAT was never an issue with the Procharger, but it would slowly climb during a pull. Nothing significant but it did slowly increase. Now with 50/50 water meth my iat drops during a pull. On an 80 degree day my iat was about 90 after a long drive and during a pull it dropped into the 70’s. I stopped after the pull and the aluminum intake was cooler than it is while idling in the garage at full operating temp.
I have about $250 in my meth kit. I’m at low 11’s afr and 18 degrees peak timing. I’m running such a small amount and with ethanol in the main tank if it fails nothing will get hurt. Timing mark moved a little cooler with the meth and all plugs look equal so I could probably add a degree of timing, but I already have more power than I can use and it’s a safe tune up so I’m leaving it.
or you can buy a pump and hobbs switches and rig up your own.
Water/meth has soooo many options really.
Do you have methanol at local race shops you can buy by the gallon? With a flex fuel sensor you can dump straight meth into your tank as well. A 30% blend of meth and pump is pretty potent. It would put you miles ahead of any typical meth inj kit. Also don't need to worry about distribution that way.
As far as a kits concerned it depends how involved you want to get and how much performance you want out of it. If you want the simple KISS low volume washer fluid kit, there's no reason to pay kit prices IMO. Just build it yourself as mentioned. If you want a 100% meth kit that will likely get you the most gains the alkycontrol kits are the best IMO. Customer support is VERY good and they are the only kit i'm aware of that's truly rated
for 100% meth.
for 100% meth.
What level of ethanol would it take to compare to a 30 percent blend of methanol? Are there any benefits to e85 over 30 percent methanol other than cost?
The blending/FLEX tables on the Mega Squirt are all I'm familiar with. You can simply input fuel multiplier for 100% mixtures. With a 100% ethanol fuel, the default multiplier is 163%. (I found 168% worked better for my setup) Then the ECU calculates the percentage of enrichment based on the ethanol content between 0-100% reported by the flex sensor.
With methanol its basically a 200% multiplier instead of the 163%. I'd input those numbers and add 10% methanol and see how it acts/reads on the WB02.
A Buick buddy mixes his own "M50" 50% 91 (ethanol free) and 50% methanol race fuel. He doesn't use a flex sensor and just tunes for that specific fuel. His setup runs extremely well, with zero signs of detonation at healthy boost and timing levels. Doesn't seem to have any of the annoying side effects seen with 100% methanol fueled vehicles at 50% either.
On sprints running straight Methanol I have to flush the lines after each day with gas to keep the grunge crystals from forming.
Additives work to control it,, I use Klots specifically but only because that's what the shop I hang around carries..
I agree 100% methanol is pretty bad stuff. Much more so than ethanol. But I've seen no signs of anything you speak of in 50% quantities mixed with standard fuel. I have seen all of what you are talking about and more on 100% methanol fueled engines. Same with E98. It gunks up my carbs like nobodies business. And any exposed alum is toast in no time. As with the 50% meth blend though, I see none of this with 50% ethanol blends. I do see issues with E85.
I use 11.84 for stoich when tuning to straight 50% ethanol.
So fuel consumption between 30% meth and 50% ethanol should be fairly close.
I have a MAT sensor, and blow off valve in that short area, but could fit it somewhere in there. Should be a learning curve for sure.
