408ci twin turbo size?
Well like the title says looking for ideas on what size turbos to run. Car is street raced for the most part but looking to turn it up a lot and start racing some track stuff.
Setup on the car now,
1990 Pontiac firebird
Engine408ci dart lsnext shp iron blockCallie's dragon slayer 4.00" crank
Callie's ultra I beam rodsWeisco pistons with tool steel pins9.8:1
trick flow genx 255 LS3 6bolt headsHolley single plane with elbow and 102mm throttle bodyHyd roller 238/242 629/621 116+5
Ms3 pro ultimate ecuHolley 160# injectors
e856gpm fuel pump
TransFreddy brown th400
Rmvb foot brake
Ultra bellHuges bolt together converter
Rear end
9"
35 splin spool3.50 gear
Dual 4 piston calipersStrange adjustable coilovers28x10.5 or 275 radial
car currently has a s475 t6 on it, I was looking at doing twin t4 1.10ar s475s but wasn't sure if they would get the job done
e856gpm fuel pump
Rmvb foot brake
Rear end
9"
