Afr per lb of boost
Old Jul 19, 2021 | 08:01 AM
nitrouspaul's Avatar
Default Afr per lb of boost
Street tuning my ls2 with twins and 12 lbs. I have my pe coming on 3500 and a gradual rise from 1.10 eq at 105 map to 1.3 eq at 205 map
it runs rich down low and my lamda curve on the wide band is .84. I was wanting to know say at 4000rpm and 140/150kpa what you guys run as an afr and curve up from there for now I am gonna move the activation rpm up to 4000 to try and avoid the rich smoke and sputtering down low but it will go lean a bit as my twins build boost fast ,need this sorted before I go to 20 lbs, thanks in advance also I will richen to .80 lambda above 150kpa
so asked another way is there a afr chart vs boost that one can use for Ls style engines
Old Jul 19, 2021 | 10:07 AM
BCNUL8R's Avatar
I’ve always had boost enrichment start as fast as possible at 105 kpa and drop to 11.5 afr as soon as possible without issue.
Old Jul 19, 2021 | 10:14 AM
thanks but it’s overloaded with fuel if I dump to quickly and my lambda is only at .83
Old Jul 19, 2021 | 10:43 AM
BCNUL8R's Avatar
Thats odd I can drop down to mid tens on afr immediately and not bog or smoke.
Old Jul 19, 2021 | 10:54 AM
ddnspider's Avatar
All depends on how much timing you put in it. You can run leaner with less timing or fatter with more. You dont really need anything richer than NA PE until you're over a couple psi. if you put some timing into it in that region it'll light off faster too.
Old Jul 22, 2021 | 03:20 AM
gametech's Avatar
Active Streak: 30 Days
Active Streak: 60 Days
It does not matter what anybody else runs. Your fueling is already not doing what you are attempting to command. This absolutely needs to be sorted as a first priority. Once you get a handle on getting your fueling to match your attempted commanded fueling, then you can figure out what is optimal. Until then any attempt to match some ideal fueling curve will still result in unpredictable issues.
