Best way to kill power at launch
cars a small tire car right now with full suspension. The car itself has everything needed to make it hook. I’m just helping out with the computer part of things. Surprising to me how many people don’t want to learn how PC side of things work. Not too bad when start seeing your changes take effect. Obviously I’m still learning myself but the changes I’ve made so far has help the car a lot.
If the car is on a slick you'd want some wheel speed. If you are on a DR, you want the opposite and may want to look into what the typical suspension approach for that car. For example on a 4th gen, on a DR, folks would typically have the rear shocks separate after the leave, extend 2.5 inches or more. But chassis stuff all depends on the track and the tire and other stuff.
May as well hang beater bombs weight bar off the back too!
