Best way to kill power at launch
my question is what way do you change the tune when your not hooking at the track? No time for suspension changes or chassis stuff. Set a lower 2 step for less boost then kill timing for a moment?
the Holley has a setting to set boost control for X seconds I think after releasing the brake. issue though is car makes bunch off spring pressure. So can I kill the timing during that window on a different map?
right now it’s in 16psi spring pressure and he was spinning pretty good last time at launch and the. It carries the spin of course.
so we can lower 2 step to have less boost to hook but if he spins 10-20’ out is what I’m unsure of. Once he’s launched I’m sure the car will flash to stall and go.
May as well hang beater bombs weight bar off the back too!I agree with other posts since its on Holley its super easy to setup boost control and timing retard tables to meet whatever need he may have.
Gotta do what ya gotta do! Esp. if you don't have drag specific suspension capable of putting down big power. I happened to be in that boat with a pretty poor setup in the Rx-7. I was at 28-30* on the 2step and dropped down to 10* on the TB release for 2.2 seconds, then ramped it back in.Believe jack roberts and capizzi both have single digit timing on the TB release for a few seconds so they could launch at big RPM and boost and ramp the power in. Both in the 1.1x 60' range as well I believe. Then if their traction control kicks in, Capizzi said he is in the negative timing on the launch for a few seconds.
The SBE guys are probably trying to keep the load off until higher RPM as well as fighting traction. Did anyone ever beat the 7.1 pass?
I have speed sensor off driveshaft only. Was going use that for boost in future. Car has a tune for 28psi so it puts out plenty if wanted. For now we working on hooking and running on 16 since that’s the min. Afterwards I can start adding boost when cars moving.
cars a small tire car right now with full suspension. The car itself has everything needed to make it hook. I’m just helping out with the computer part of things. Surprising to me how many people don’t want to learn how PC side of things work. Not too bad when start seeing your changes take effect. Obviously I’m still learning myself but the changes I’ve made so far has help the car a lot.
is it possible they are slacking on the suspension side for it to grip and go? Yes very much so but I wouldn’t be able to help them do that. They have around 1100tq to work with and they spin good. Lowest boost has power down further than that but the timing maps are the same so the tq is always high.
