Summit pistons, rod length vs boost
So would the longer rod length be more suitable for boost, better side angle.
Plan on using the stock crank, 317 heads.
#PR360053, 4.005, 6.098 rod
#PR36L0052, 4.005, 6.125 rod.
The SUM-PR3603012 uses the stock length of 6.098" for the rods.
The SUM-PR36L03012 uses the common longer 6.125" rod length.
Either of these is good for 1,000 whp out of the box.
What does that difference mean?
Shorter rods: Shorter rods mean the overall height of the block can be shorter, which means the overall weight of the block can be lighter. The engine will typically pull more vacuum at low RPM, which means better throttle response and low-end torque (good for street performance and everyday driving). Spark timing can be advanced a few degrees for some additional low-speed torque, and the engine is less prone to detonation, which can be a plus in turbocharged, supercharged or nitrous applications.
Longer rods: Using longer connecting rods with the same stroke reduces the side loading on the pistons, which reduces friction. It also increases the piston dwell time at Top Dead Center. Holding compression for maybe half a degree of crankshaft rotation longer at TDC improves combustion efficiency and squeezes a little more power out of the air/fuel mixture. Typically, an engine with a higher rod ratio will produce a little more power from mid-range to peak RPM.
The pistons are different to accommodate the associated rod length. Our pistons will be .005" in the hole at TDC. This is no matter of 6.098" or 6.125" rod length. Factory is around .004-.005" out of the hole at TDC.
Let me know if you need any further assistance and I'll be happy to help.
Thank you,
Joe
I thought about building a 403 stroker, but years ago I pulled a 6.0 out and did this, didn't think it picked up as much as I thought it would, running 12 lbs boost.
The theory I believe was the additional piston dwell time provided the needed combustion time for the poorer quality fuel to burn, does that apply to FI, that's a discussion I'd love to be a fly on the wall for.
I'll have to join YB and check out those discussions/debates as well.
