LSX376 Users - Come In
Anyone know the purpose of those 6 tapped holes in the valve covers? Coil brackets?
Motion Raceworks has some adapters to put a breather line off the valve cover without welding. You drill a hole in the cover, and the adapter sandwiches the cover with o rings. That might work for you. But, I understand not wanting to mess with those covers…
Is it possible to remove the steel lines from the VC's and tap them for NPT?
3/8" hose was fine for my old car at 5-6 lbs. but became an issue at 10 lbs. then I moved to a single -12AN line which was sufficient to support 14 lbs.
Easy to do and keeps the hose clutter out of the front of the engine bay.
My current setup uses two -10 AN lines to a single large catch can.
You can just see the can on the front passenger wheel well behind the intake pipe.
Undecided on coil placement. Car already has IGN-1As mounted on the inner fenderwell. Hmm. But, I also like the clean look of no coils on the engine, especially with those valve covers. Did I ever say I love those valve covers?
All the accessories are in place for mockup, except the ATI balancer. Using a small case AD230 alternator in the Corvette location and the mockup will be replaced by a Powermaster, 1-wire, 165A unit. Not surprisingly, ended up with trusty truck manifolds.
Did my best McGyver to come with a way to support the 40lb VSR billet 85/102 and have side-side, forward-backward and up-down adjustability to come up with the final resting place.
First order of business is the turbo support with a Maven mount, looking something like this but more of a 90* bend to bring it closer to the frame and with additional support.
You can't see the fittings on the cover but you can see how I routed the hoses.
I think the only downside may be condensation collecting in the form of that nasty white gel in the valve covers, the gents I mention haven't seen that but that's all I could think of.
Making progress. Turbo support, ATI balancer and alternator done in the Corvette location with a Powermaster small case AD230 and ICT Billet alternator bracket. trying to find a 3" alternator pulley. Started on the manifolds-to-turbo hot side but waiting on a set of 2.25" pie cuts.
