LSX376 Users - Come In
I read those threads as well and became more confused as I went. Even the Holley website is a little ambiguous.
The aforementioned AC416 fits as is and the pinout is correct; we'll see how it behaves when I fire mine a few weeks from now, at most.
Thanks for the info.
Andrew
Put a tune together based on the Volvo. AE needs work but it drove without issues.
So quiet you can hear the intake charge in the sheet metal plenum.
Randomly popping in and saying "X motor sucks, I broke one twice" with no other information is silly and counterproductive.
Owner has been driving the car everyday in mid-90s FL weather. Big shout out to Andrew (ProjectGatTagO) for helping out with the tune. I initially left it on the 6psi WG pressure and had him slowly raise the shift light RPM as he put miles on the engine. He used to run 15+psi with the Keith Black 540ci MOPAR with Indy heads and a Procharger and said it used to haze the 325 DRs in 3rd and so 6psi with the LSX felt "slow". Sunday I turned on boost control with a target of 12psi dome pressure and set the boost safety to 14psi just in case. Got a call saying he just got a big scare. Not expecting a turbo 376ci with 12psi to match a s-charged 540ci with 15+psi, he got on it and the car starting going sideways in 3rd and almost lost it. He has yet to go over 5500 RPMs! You can guess what his Butt-meter is telling him when comparing the 2 setups. After thinking what 6700 and 20psi might be like, all future thoughts of upgrading the LSA rods, pistons and Cam are out the window. He's got all he wants. No oil leaks, starts right up hot or cold, smooth, quiet and scares him.
To say he's stoked is an understatement. MOPAR purist be damned!
What made him make that change?
Love that he's enjoying it especially in that heat, I loved my old carbed LS6 454 car but the fuel injected turbo LS is just so much more pleasant to drive.
The KB had valvetrain misalignment issues and was needing a 3rd rebuild. It ran hot and on summer days like now, needed at least an hour before it would restart, leaked oil worse than an OEM MOPAR big block
and the 727 had issues.........then he took a test drive in the Volvo
. Seriously, he was just frustrated. Selling the damaged KB block (couple of wiped out lifter bores), the Indy heads, Pro-charger, 727, etc, etc, financed almost the entire swap, LSX longblock, TH400, PTC converter and upgraded suspension. Still has the numbers-matching 440ci and 4-spd even though they're never going back in the car.
. Seriously, he was just frustrated. Selling the damaged KB block (couple of wiped out lifter bores), the Indy heads, Pro-charger, 727, etc, etc, financed almost the entire swap, LSX longblock, TH400, PTC converter and upgraded suspension. Still has the numbers-matching 440ci and 4-spd even though they're never going back in the car.I guessed running hot might have been an issue but the rest, damn.
It's amazing how bad drivability can take all the pleasure out of owning a car.
My 99 turbo Camaro ran really badly when I got it, I tried tuning it myself but was unable to for various reasons and I started to wonder if I'd made a mistake in purchasing it.
After breaking down and hiring Pat G. to tune it, my outlook has completely changed, the car is so nice to drive even with manual steering, brakes and TH400.
Well I hope he enjoys the hell out of it, sounds like his love affair with the car has found a new lease on life, thanks to you.
