Hot side tubing/bends
I think it will depend alot on the engine used and its na power output. Mild motors would benefit much less from the larger piping. Makes sense with what I've done anyway. Not saying its "right". The diff between 2.5" to 2" was pretty night/day on my mild 5.3. went from not being able to spool the T4 S475 turbo at all, to spooling it very easily. (had way too tight of a converter and lazy compression). Then stepping up to a T6 S480... and spooling that very quickly as well. Not that a proper 2.5"/3" setup can't do the same. But with my particular setup/tune it couldn't and the only change was a 2" hotside.
And even if there were no benefits or draw backs to either power/spool wise. Smaller piping is much easier to package, is cheaper, and is thicker wall to boot usually. Not to mention a 2.5 or 3" pipe doesn't neck down to a typical T6 divided flange inlet well. Easier to double wrap etc. Wouldn't' suggest it for 4 sec drag cars but for street strip burnout machines its more than enough for 1000ish crank hp in my experience.
I've don't usually have a problem spooling turbos, I had 3" off the manifolds with twins so I knew dual 3" into a twin scroll T6 would only be faster. Pretty sure the SBE 5.3 record guys also run dual 3" to a GTX55 which has been proven to work well, granted they are running 40PSI at 8000+ RPM so the increased airflow helps.
2.5 vs 3" is about a $3 difference in material for me so not much saved there. The headers have 3" vbands so I dont need reducers to need to neck it down, and I run a flange like this which makes it easy on the turbo side:
Also if the scroll exit is approx 1.6" on a 1.32 T6. I just can't see needing 3" piping feeding each side of that. If the bottle neck in the system and wheel restriction dictates the drive pressure... whats the benefit of having big 3" pipes before that? Stepping up and down exh speed all over the system seems odd. I'm not doubting it works, or that people see results at huge power/rpm/boost. I just don't understand it fully.
