Sbe oil pans
Old Nov 9, 2021 | 08:27 PM
bb69chevelle's Avatar
Default Sbe oil pans
I have a 69 chevelle with a gen 3 6.0 s475 turbo f body oil pan. I am going to be pulling it over the winter and putting in a gen 4 5.3 with the same turbo and I have been having some oil issues I believe is cavitation above 5k Rpms. I have a Holley dominator edition on it and I am datalogging oil pressure. It climbs to around 50 psi and then levels off and doesn’t climb anymore. I am running an extra quart in it. I was wondering what oil pans everyone is using on the sbe motors. I also have a Melling 10296 pump in it with a red spring and a 1/16 shim in it. I will be changing the pump to 10295 when the other motor goes in.
Old Nov 10, 2021 | 04:33 AM
yenkomike's Avatar
The ctsv oil pan fits a chevelle a lot better than your f body pan . And is just a better pan for oil control
Old Nov 10, 2021 | 10:04 AM
Thanks for the reply have had one of those on a car that is spinning north of 7k . If so how did the oil pressure look.
Old Nov 10, 2021 | 05:18 PM
ls3fox's Avatar
7 Second Club
I run a ctsv pan 8000 rpm 7qts no oil pressures dips or drop off at all with a stock dod oil pump
My buddy runs the moroso oil pan not sure which one we tried up too 8 qts and it’ll make 65ish psi then fall off to 58 ish 10296 pump
if your gonna run a melling pump I would run the 10355hv
Old Nov 10, 2021 | 06:21 PM
Thanks for the response. I will look into that ctsv pan. Anyone else have any oil pans they are using with success.
Old Nov 13, 2021 | 09:37 PM
jayyyw's Avatar
I ran a C6 vette pan. Spin the engine to 8200rpm and no issues with oil pressure
Old Nov 13, 2021 | 11:31 PM
RonSSNova's Avatar
Stock pan? No fancy baffles? I see pressure drop on my C5 with a C6 pan on the launch at the track unless I put 7qts in.
Old Nov 14, 2021 | 05:32 AM
jayyyw's Avatar
Well, street pulls. Never took it to the track.
Old Nov 14, 2021 | 09:50 AM
RonSSNova's Avatar
Ah. Got it. Thanks.
Old Nov 17, 2021 | 06:04 AM
Thanks for all of the replies. Good information
Old Nov 17, 2021 | 09:43 AM
Forcefed86's Avatar
Where is your turbo drain? Jack the car up level and start it. Then add oil until it just starts to come out the pan drain hole. You'd be surprised. Mine barely started to dribble out at 8qts. Run like 1/3 of a QT less and go. Ran the Fbody pan down into the 1.3x range at the track with the front wheels in the air with no pressure drop. (factory DOD pump). most don't overfill enough IMO.
Old Nov 18, 2021 | 08:15 AM
Force fed that is a good idea. I am currently running 7 qts. When I was running 6 qts in it the oil pressure was dropping off after adding another quart it came up with rpm and leveled off at about 50 psi no matter how high I spin it, which has been 7200. The drain for the turbo is in the top of the pan about midway back on the passenger side.
thanks everyone for the ideas.
Old Nov 25, 2021 | 05:45 PM
jester1's Avatar
I have the Moroso steel pan 20140 pan with -10 lines for remote filter. Unfortunately can't say how well it works but fits great for anyone wondering.
