High compression 408...t4 turbo?
I feel like a 408 with high compression is gonna max out the 96mm turbine much sooner than say a 5.3/5.7 but it still should make plenty of steam.
A T6 with a big 110/114mm exhaust wheel would be the ticket but is gonna be $$$$, or there's twin 7875's if you decide to make a change.
There's a gent on here with a 370 and a 7875 running mid to low 9's in a heavy 4th gen Firebird making good power so you should be able to easily do better.
That 96mm will certainly open that rpm window up though but you outta be able to hit 900whp maybe 1Kwhp.
There's a local guy here with a 408 80/96 T4 setup in a six speed car and he made 750whp on pump and 1Kwhp on race fuel.
Of course you may lose a little more through an auto and an auto will load the turbo differently than a manual but the reference is still sound.
He would need a pretty sizeable turbine to use that 408 efficiently though wouldn't he?
Trying to remember what size Garrett @randeez was using on his single 427 in his Escalade.
Highly suggest seeing what it would take to convert your T4 setup to a T6 flange. Don't think its necessary to revamp your existing setup just for a flange difference unless the turbo placement won't fit a large frame turbo.
i never tried a T4, smallest i had was a T6 BW80/96 1.32ar iirc - spooled up like a diesel but had about as much usable rpm. i probably have some logs showing it not able to keep 15psi past 5500rpm
as said above this is with a 427, 10.5ish compression is what they shot for i think, same m311 heads
as said about this is with a 427, 10.5ish compression is what they shot for i think, same m311 heads
Seems like from what you said its a much better turbo over the big VS unit you were using before.
If you have problems making 900hp on a 408 through a T4 96mm turbine or burn up exhaust guides valves whatever, you've got other issues. Maybe the people burning **** up are running 100% M1? Would be huge volume but the egts are relatively ice cold, so that doesn't make sense either.
But I wonder if the exhaust valves are floating on these deals when burning up valves and guides. I once ran a pretty small XER lobed cam (aggressive ramps and should be used in aspirated applications only) and with that cam, even with good dual valves, it floated the valves so easily, around 15psi like you saw, this was a PT7675 on a 6.0. I changed to a cam with gentler lobes LSL and the problem was gone, never had the problem or thought about it again.
Just wanted to throw that out there...lots of stuff could make exhaust valves float/bounce on a turbo deal, and b.p. is involved, but violent max effort lobes will exponentially amplify the problem!
