Tick A2W Intercooler questions.
Old Jan 10, 2022 | 04:12 PM
Boostcreeep's Avatar
Default Tick A2W Intercooler questions.
Hey guys,
I've currently been kicking around the idea of buying the Tick performance 1400hp A2W sandwich intercooler/holley lo ram combo. I've seen plenty of data on the shearer fab ones but haven't seen much user review for the Tick set-up. How does it perform? I am currently running on E85 hot directly into the intake for plumbing/real estate issues on my car and have really been interested in buying that to save me more fab work reworking my currently hotside and making a new cold side with a A2A.
Old Jan 11, 2022 | 09:53 AM
SLOW SEDAN's Avatar
No matter what brand the thin versions don't seem to work that well unless you run low boost, which is probably why Shearer only makes larger versions. It looks like the price difference is only $130 to get the 1700hp version that is guaranteed to work if you have the room. What turbo do you have and how much boost do you run now and what's your goal?
Old Jan 12, 2022 | 02:47 PM
Sorry for the late response.
I have a VS485/103. The motor is a aluminum LC9 with a piston/rod combo. As far as goals go; I honestly don't really have a goal. The car was previously a NA/NOS deal and this is my first turbo set-up. As far as clearance go I'd need to remeasure for the Shearer rig but I'm pretty confident it will not clear my hood. I originally thought I would be completely fine with just running E85 and pulling some timing vs temp at the track as the car is slowly turning into more of a race car than a cruiser. My thought was if i could get an A2W set-up for a reasonable price then maybe it wouldn't be bad attempting street driving/cruising. Also, I know without a doubt It would be safer and I could lean on it harder when the time comes. I also had no idea the bigger shearer version was only 130$ more. I'm praying that ill have hood clearance lol
Old Jan 12, 2022 | 04:14 PM
SLOW SEDAN's Avatar
I've run the VSR 85/102 without an intercooler and it wasn't bad at all on E85, will certainly work to get you started just don't get greedy with timing or boost off the bat. At the end of the day its certainly more easier leaning on them with an IC and of course can make more power.
I was incorrect, looks like its about $230 these days. I've run the shearer one in the past and didnt even need water in the core for it to stay cool on short street hits. The thin tick unit just reminds me too much of the smaller 417 unit which really isnt suited to higher boost on something like a 5.3L.
Old Jan 13, 2022 | 07:18 AM
Black_Sunshine_99's Avatar
Don't be a *****, ditch the hood. ; )
Honestly though, you might crash ogling that gorgeous billet masterpiece instead of watching the road lol.
Old Jan 13, 2022 | 09:09 AM
SLOW SEDAN's Avatar
Everyone else stares at it too!
Old Jan 13, 2022 | 02:26 PM
I'd love to have one on a high ram but in my 4th gen that would require me to chop and hack way, way too much lol.
Old Jan 19, 2022 | 09:55 AM
Old Buzzard's Avatar
Ditch the cooler idea and use 100% meth injection and the E85?
Old Jan 24, 2022 | 05:35 PM
Pro Stock John's Avatar
LS1Tech Co-Founder
Community Influencer
I have a few friends working on Holley Lo-Ram + a/w brick (SheearFab for one, Tick smaller one for the other Hi Andrew), I'm looking forward to their results. The first combo is a <3400 1st gen with big twins.
Old Jan 25, 2022 | 02:30 PM
John please post the results!.
I know I cannot be the only one looking for any real world data on the tick ones!
Old Jan 25, 2022 | 03:06 PM
LS1Tech Co-Founder
I will goad the guys to share info, the 1st gen guy is still an active member on here actually.
Old Jan 26, 2022 | 01:59 PM
Project GatTagO's Avatar
I have the short Tick brick on order. I plan on using it with a Holley Low Ram base.
Andrew
Old Jan 26, 2022 | 02:12 PM
SLOW SEDAN's Avatar
Andrew
Hopefully it works better than the 417 short version, but they probably use the same core so I'm doubtful. At 19-20PSI my non intercooled IAT's were same as the 417 unit in a high ram
Old Jan 26, 2022 | 02:24 PM
Time will tell.
Andrew
Old Jan 26, 2022 | 03:08 PM
LS1Tech Co-Founder
I feel like the 417 version didn't get enough data, maybe folks were using them for power goals that exceeded that part's abilities.
Old Jan 26, 2022 | 04:31 PM
SLOW SEDAN's Avatar
Did you miss the VERY detailed thread on the 417 intercooler? Everything was tried to try to get this thing to perform but their "1500hp" rating couldnt handle well below that. 417 Motorsports 1500hp Hi-Ram Intercooler: The Data - LS1TECH - Camaro and Firebird Forum Discussion
Old Jan 26, 2022 | 05:25 PM
LS1Tech Co-Founder
I remember it, re-reading it now to refresh my memory.... brb.
Old Jan 27, 2022 | 02:30 PM
I felt like that was the case in the post Slow Sedan shared but was really telling was how LJMS/417 failed to step up and make it right.
Another member on here bought a Shearer cooler like the one the gent with the CTSV went with and his actually failed at one of the welds after much abuse and Ron took the old one back and sent him a new one no questions asked.
I would do business with Shearer based on that, the quality product and the results realized, a trifecta for success.
Old Jan 27, 2022 | 02:57 PM
I have nothing against the Shearer intake, but I have packaging constraints.
Old Jan 27, 2022 | 02:59 PM
LS1Tech Co-Founder
I completely re-read the 417 thread, it was very detailed because of all the testing the guy did. I'm not sure what the final verdict was, core too small or some other issue?
