Cracked heads
Old Jan 17, 2022 | 03:45 PM
BLACK-00-WS6's Avatar
Default Cracked heads
Has anybody tried running 823 heads with cracks between the valves in a boosted application?
Old Jan 17, 2022 | 05:22 PM
chevymec's Avatar
Why would you even want to take a chance like that?
Old Jan 18, 2022 | 08:28 AM
badass68's Avatar
It'll be fine. Very common.....
Old Jan 18, 2022 | 08:44 AM
Tyler Dietzenbach's Avatar
I have some 799s with the same type of issue.. It's very common.
Based off my research, which I feel like was fairly extensive, the general consensus was they should be fine BUT several guys noted that under heavy boost there is some risk.
It's up to you if you want to take the risk. Hope that helps.
Old Jan 18, 2022 | 09:05 AM
AwesomeAuto's Avatar
There are guys running 7s that say their stock heads have that small crack.
