Crank and Rods Suggestion
Is the stock cast LS3 crank and stock rods sufficient for this? Pistons will be forged. I think typical choices are cast iron LS3 crank, forged steel 8 bolt LSA crank, or Chinese forged 6 bolt crank. I’m probably not in the territory to consider above that.
Same on the rods, stay stock, or Chinese H beams?
I have seen a few posts say the stock cast crank and rods are good to nearly 1000hp, but I wanted to get some opinions before I start putting this build together. Max RPM will be 6,000 or less.
Thanks.
I'm spec'ing a budget boost build with Summit now, 1000-1200rwhp goal.
