air to water pumps
first is the zzp pump
second bosch pump
and last is davies craig
with the davies craig would i need the screen thing for it to work properly. the setup is going to have a small 3L tank since the car is going to be a daily with a heat exchanger i might add a ice tank later on in the trunk, im aiming for 500-600 hp.
I'm also an using a Rule 2000 pump for my A2W system, it also works really well.
Don't think you could go wrong with either of those options.
Honestly, when putting around on the street I don't even turn it on and my IAT's stay low.
The stagnant water in the A2W cooler by itself is an incredible heat sink.
https://tecomotive.com/store/en/wate...150-water-pump
Andrew
https://www.summitracing.com/parts/d...IaAi8lEALw_wcB
https://www.fordgt500.com/threads/in....192975/page-2
I've used the rule and they dont like contnuous duty.
zl1 pump is weak. Same as most stock intercooler pumps.
tried a moroso electric water pump and it didnt work well preobably for the previous posts reasons.
I have heard the gt500 pump blackbird mentioned is good but don't have personal experience.
Also what do you consider continuous duty, running for hours on end or only running when racing or dyno testing?
Gracias!
I did some searching and found this, great read.
Supercharger Thermodynamics; Impacts of Coolant Flow Rate on Intake Air Temperature.
Andrew
Andrew
What’s the cost of that?
Ty
jimbo
Mine is in the reservoir so I would imagine that would greatly help combat high temp. issues.
you can pick them up clean off ebay for 100bux. they draw like 40amps wide open though lol. ive just got it connected to a manual pwm controller, it rarely sees over 50%
