How much power is my cam costing me?
#41
Ahh Dynocom dyno, that's user configurable and will read however the operator sets it up. I immediately throw out any result that comes from a dyno like that. Those types of dynos are great for dialing in steady state or targeting particular areas, applying a large load, and direct comparisons to the same vehicle/same config on the same dyno, but never try to compare the numbers that come out of those to anything else.
#42
I think you quoted me on accident because I said nothing of the sorts.
#43
So your current combo is this:
Engine: 416 LT stroked
Compression: 10.5:1
Heads: Stock
Fuel: E85
Cam: Blower grind
Turbos: Twin Comp 68/71 1.06
Trans: 8L90E
When you reference the car that made 1200rwhp, you said it ran the same turbos, and was it the same fuel? Are both combos the same a/a or a/w setup?
Key question for me is how many lbs of boost did the other car have to make to achieve 1200rwhp?
Compression: 10.5:1
Heads: Stock
Fuel: E85
Cam: Blower grind
Trans: 8L90E
#44
I quoted your post intentionally, but perhaps projected my viewpoint of a lot of users onto the intent of your post. User configurable tools can be very repeatable if they are properly used, but they have the ability to be manipulated at the whim of whatever jackass is using them. Apologies if it seemed I was putting words in your mouth.
#45
This... that cam has way too much exhaust duration. The turbos should be sufficient to go 7300 7500 on that motor. However, im pretty sure you are losing power due to excessive overlap. Like the quote above, most turbo grinds generally run around an 8 degree split between intake and exhaust on an efficient combo. Additionally, the timing events for a blower cam is not ideal for a turbo due to backpressure made in the hotside. I'd bet if you changed the cam to something like 238/246 on a 114.5 or 116 you'd pick up power everywhere and the system as a whole be happy.
#48
#49
#50
Compression: 10.5:1
Heads: Stock
Fuel: E85
Cam: Blower grind
Trans: 8L90E
Compression: 10.5:1
Heads: Stock
Fuel: E85
Cam: Blower grind
Trans: 8L90E
#51
#52
#53
Others may have said it, but boost is entirely different betweeen Supercharger and turbo. The first thing to acknowledge is exhaust back pressure, Ambient air is 14.7 lbs. pushing against the intake and exhaust valves. Exhaust is pushng against 14.7 lbs. PLUS the exhaust systems bends and length. A supercharger is free of the pressure ratio. Spin to the world and make boost. A turbo must balance its freedom on the intake side with the restriction it introduces on the hotside. Hence the difference in overlap. For this reason a Supercharger or Nitrous cam is very different from a turbo cam
The following users liked this post:
The BallSS (04-08-2022)
#54
I believe its the cam. My sbe ls3 made almost 1100 on 16 lbs with stock heads, vs 6766 twins, fast high ram and a smallwood solid roller. That cam is 236/244 114.5 with btr ultimate rpm springs. After lash the duration is actually around 232 240 with about 6 or 8 degrees overlap. It peaked around 7500 with that combo. Your engine has larger turbines than mine so it should peak close to that on your 416 or maybe a little lower, but the hp number should be higher. I would just about bet the farm that if you changed the cam, couples with the right valve spring your power goals would be reached. Too much overlap on a turbo car is way worse than too little. It's the cam and springs. Gotta be.
#55
#56
#58
#59
#60
That is what counts. Hell, I have trapped 129mph in a 4000lb car before that only dynoed 509hp. We found out old dual roller mustang dynos can have serious wheelspin issues. The trap speed vs weight is an excellent indicator of actual power.
