Procharger clocking
Old Apr 15, 2022 | 04:44 PM
mstansbury0704's Avatar
Default Procharger clocking
Have a question about clocking on a P1sc/D1sc. Pretty odd that both units in question have same exact issue. I recently got a D1sc used. Unsure if it’s ever been popped open by a third party..Procharger states it’s 10o clock reverse (they last had it in 2010) and everything on the outside coincides with that, drain plug and tag). I did try to check, no way the case would come off.
my friend has been piecing a procharger build together on his vette with a P1sc for like a year and a half now. SAME EXACT problem. Can’t get the case half to come off(these are both older units made in early 2000s). I got the bright idea of using the headunit mounting bolts as grab points and a locking vice grips slide hammer tool to try and get the case to pop and walk it off…any thoughts on this? If I could get my case off I’d love to verify my clocking is still the same as when procharger had it. My friend on the other hand is certain he needs to change his. Thoughts on how to get stuck cases to pop loose or has anyone done anything different?
Old Apr 15, 2022 | 05:14 PM
KissMyTushZ28's Avatar
They are on there pretty damn well, it's not as easy as clocking a turbo. My P1 on my GTO was clocked just enough to have one of the front face bolts in the way of the drain plug. I loosened everything and tried moving it, nothing. I didn't have a torch handy so I set it out in the sun for about an hour, braced the body against my torso and smacked the snout. It turned just enough for the drain plug to clear that face bolt. So it takes some work to get it off I'm sure.
Old Apr 15, 2022 | 06:01 PM
I’m not talking of spinning the volute. I mean actual oil slinger inside the case. Idk why I posted this to fuel/injection! I meant to post in the forced induction, oops
Old Apr 15, 2022 | 06:37 PM
Oh you didn't mention anything about that. You ended it with talking about getting the case off, so I was explaining that it doesn't come off easily. It takes some effort. Good luck with fixing that oiling issue. There are rebuild kits for them that you can buy that come with the internal seals. Or you can send it to Procharger.
