To stroke, or not to stroke? LQ4 LSA
appreciate your opinions.
. Here's a thread with some good info and parts on that topic. Gonna need a good 4L80E
. Here's a thread with some good info on that topic. Gonna need a good 4L80E
With that said if you end up upgrading the blower you could easily move to something larger (Whipple, Maggie, TVS) and make a lot of power easily.
A 408 with a bigger Whipple or that TVS2650 unit will make quite a bit of steam, easily into the 900+ range.
How many lbs. are you currently on your combo?
Any idea how high you can turn it up before it becomes a heat pump?
The stroker crank increases your displacement by 8.5%. In a perfect world that would be 8.5% power, but you can gain 8.5% power other ways, like a better supercharger, better heads, or put that big crank money into other things further down the line in the car.
The stock crank is very strong, capable of supporting over 1000hp.
Just something to consider.
Basically your basically ruining a stock block setup that way IMO. Adding a bunch of expense and down time for nothing. Add an aftermarket blower and be done. Cheaper in the long run. Cheaper still to throw a turbo on it…. But I get that’s not for everyone.
